Old 02-03-2011, 10:34 PM   #1
ant.1969
Default 2001 xr8
looking to purchase a 2001 series 2 220kw xr8. What do i need to look out for? Any simple probs any major probs? Would love to hear any comments as dont want to outlay $$$$ for prob car as have owned plenty of fal 6's with no probs. thanks all Ant
ant.1969 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2011, 11:43 PM   #2
richo77
richo77's Avatar
Have a read through the au section mate, you'll get a good response there. Alternatively look through 'common problems with the AU'.
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 01:09 AM   #3
GULL
TuRbO
Wish i never sold mine,but they do drink alot of petrol !
GULL is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 08:48 AM   #4
JC
JC's Avatar
Just the usual - make sure gear box is smooth, look out for diff whine, check radiator & oil etc. The advantage of buying one of these things, is that even a relatively major mechanical fix is still cheaper than some of the later models cars.
Ford Performance Club ACT
Old 03-03-2011, 09:40 AM   #5
FTe342
FTe342's Avatar
Common IRS problems are top shock mounts and rear wheel hub bearings.
Great cars but getting on a bit. Get cooling system pressure tested as if radiator has not been replaced it won't be far off
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 11:46 AM   #6
b2tf
not here much anymore
b2tf's Avatar
Compared to a BOSS they use bugger all and yes I have owned both.
2024 F150 XLT
Old 03-03-2011, 11:57 AM   #7
WannabeXP
WannabeXP's Avatar
Rust in the boot and under the rear bar
Cheers Jason
WANTED: MOMO Metallic blue steering wheel and Manual gearknob! PM Please!!
Stevo
_____________________________________
05/2000 AUII XR6 5sp|Pacemaker 4480 Competition Headers|Lukey catback|Tickford Azzuro's|Impco LPG Conversion
WannabeXP is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 12:35 PM   #8
Donny
Tickford 220kw Windsor...
Donny's Avatar
Same here, I have owned both and the Boss drinks plenty more juice than the weezor..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue....
2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver...
Donny is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 01:51 PM   #9
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
If you are planing to do alot of miles your face may develop a permanent grin.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 02:30 PM   #10
b2tf
b2tf's Avatar
......... and doesn't sound as good!
2024 F150 XLT
Old 03-03-2011, 03:06 PM   #11
Donny
Donny's Avatar
For sure, the weezor sounds much better. Sounds more old school.
Old 07-03-2011, 07:24 PM   #12
SSD-85
You sure you wouldnt want a S3? Ive got one here thats had all the work done already. With a stupidly low price tag....
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2011, 09:10 PM   #13
T3man
T3man's Avatar
Look out for a rogue seller. I think only Series III had the 220kW motor.
Old 08-03-2011, 01:34 PM   #14
auxr
auxr's Avatar
Nope - series II XR8 onwards have got the 220 hand built jobbies.
auxr is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2011, 05:30 PM   #15
Donny
Donny's Avatar
Slight correction, later Series 2 XR8's got the 220kw donk... And all Series 3 XR8's.
Old 08-03-2011, 08:25 PM   #16
b2tf
b2tf's Avatar
I believe the Rebels were the first AUII's to get the 220 and it was continued on after that. That was April 2001.
2024 F150 XLT
Old 08-03-2011, 08:37 PM   #17
tezxr8man
I agree get 800k's out of a tank on the highway and not too bad economy around town, does sip a bit if you're heavy footed tho. Like anything really
tezxr8man is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2011, 08:37 PM   #18
Tickford Rebel
Youngling
Tickford Rebel's Avatar
Correct only 125 Rebels in Series II were 220 kw. Only then Series III xr8 were 220kw
HOPE OUR LUCK DOSENT END NOW!!
Tickford Rebel is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2011, 08:47 PM   #19
tezxr8man
have a look at the steering rack too they hav a few dramas, done one on mine and thru the parts store where i work if a ford rack is replaced its for an AU,
not too bad tho when you look at holden racks are sold around 10to fords 1
Old 08-03-2011, 10:11 PM   #20
JC
JC's Avatar
Incorrect.
I have a series 2 with a 220 (standard from June 2001; mine just scrapes in - it was built in June 2001). The AU2 220s were around (for a month) before the AU2 Rebel (believe it or not!)
"An important 220 kW XR8 upgrade was then announced in June 2001 as an AU Series II running change. This coincided with the switch from the alloy heads for the 220 kW engine in the T-Series to the locally re-engineered cast iron heads which were combined with a larger throttle body, matched port inlet manifold and a revised camshaft. This new engine was a hand-assembled Tickford item. Sideskirts and body colour exterior mirrors were now standard.
This was followed by the July 2001 release of the XR8 Rebel which featured new Ford Racing exterior additions and seven spoke 18 inch Speedline alloy wheels. Pick this model with its grey accents and mesh inserts.
Link to the history of these cars:
http://www.fpv.com.au/theheritage/fa...onxr8-220.aspx
Old 08-03-2011, 10:11 PM   #21
JC
JC's Avatar
Or rogue TE owners!!
Old 08-03-2011, 10:30 PM   #22
macman
macman's Avatar
I can't think of anything in particular to "look out for" over the things you should be looking for with any used car.
Check fluids are clean and up to their appropriate level.
Look for oil underneath - engine, gearbox and diff. Look at the owners driveway for old puddles too. Underside should not be oily but also no harm in being suspicious of over-clean sparkling underside or engine bay either.
Make sure it drives, accelerates, brakes and corners smoothly and there are no bonks, knocks, rattles or bangs.
Check for rust in all the obvious/visible places as well as:
top corners of the boot channel (where the gas strut mounts)
forward most end of the inner sills
a-pillars where the door hinges attach (with the front doors open)
macman is offline   Reply With Quote Multi-Quote with this Post
