Old 01-03-2011, 03:15 PM   #1
wor57
Default Vibration in D/R with foot on Brake
Hey,
Broke an engine mount, so replaced them both - now have a real bad vibration when stopped with foot on brake in R or D. in neutral or with any revs the vibration is gone....
Car has new engine mounts, never vibrated before they were replaced - any ideas?
wor57 is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2011, 03:19 PM   #2
FGII-XR6
FGII-XR6's Avatar
did you do the rear mount too?
[SIGPIC][/SIGPIC]
Rides:
Old 01-03-2011, 03:24 PM   #3
wor57
as in the gearbox mount?
Old 01-03-2011, 05:26 PM   #4
FGII-XR6
FGII-XR6's Avatar
yes the gearbox mount is actually called the rear engine mount for some strange reason but my guess is the rear mount was stressed when the engine was moving around
[SIGPIC][/SIGPIC]
Rides:
Old 01-03-2011, 08:01 PM   #5
wor57
placing the trolley jack under the gearbox mount doesnt make a difference to it - mount looks to be perfect
Old 01-03-2011, 08:55 PM   #6
FYRE_81_AUI_00
woop woop woop woop
sounds like you might have developed the notorious AU idle issue
good luck mate
FYRE_81_AUI_00 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2011, 04:41 PM   #7
wor57
the exact same moment the engine mount was swapped?
Old 02-03-2011, 04:45 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
quite possibly you couldn't feel the idle problem with a sloppy engine mount, but once you got it replaced the stiffness of the mount transfers the idle problem through to your right foot effectively
i've got modified EL engine mounts on mine cos they last longer but are harder, so any idle problems i have are even more apparent than they would normally be
Old 02-03-2011, 06:30 PM   #9
natedogg1986
was the original mounts hydraulic? you may have not put the right ones back in it.
2003 BA XR6 N/A SEDAN IN ACID RUSH
CURRENT MODS: PACEMAKER 4490's, 3 INCH HIGH FLOW CAT, F6 CAI, K&N PANEL FILTER
FUTURE MODS: CAT BACK EXHAUST, MAG WHEELS
natedogg1986 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2011, 07:25 PM   #10
FYRE_81_AUI_00
woop woop woop woop
exactly as mr hardware said, that or you could have done it while you were moving the engine around abit replacing the mounts
Old 07-03-2011, 03:59 PM   #11
wor57
yea these are EL mounts in mine too
