Old 24-11-2010, 11:18 PM   #1
TK-421
Default After market stereo into AU.
I have installed a kd-r316 jvc head unit into my au and it is displaying the word "protect" when i increased the volume. I reset the unit as per the manual and is now permanantly displaying "protect".
Can anybody tell me what could cause this problem?
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 11:52 PM   #2
JC
JC's Avatar
You had it too loud, so it's gone into protect mode?
Ford Performance Club ACT
Old 25-11-2010, 12:20 AM   #3
Day-mow
rexnet
Day-mow's Avatar
heat perhaps?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 25-11-2010, 12:42 AM   #4
JC
JC's Avatar
Looked up JVC site and found this:
“PROTECT” appears on the display and no operations can be done.
Check to be sure the terminals of the speaker leads are covered with insulating tape properly, then reset the unit ( 3). If “PROTECT” does not disappear, consult your JVC
car audio dealer or a company supplying kits.
Old 25-11-2010, 01:15 AM   #5
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
JC is the man once again!
To the OP, have you looked at the JVC site or tried contacting them?
Old 25-11-2010, 10:15 AM   #6
TK-421
Yeah i read that bit on thier site. I have checked the speakers and they are the original units from factory and have the plastic clip that seperates the wires, so i'm not sure if that is the problem.
My question was what should i look for now that the speaker wires look ok.
thanks for the replies.
Old 25-11-2010, 10:20 AM   #7
Dave_Obsession
Try contacting JVC directly, at least they'll point you in the direction of an authorised repairer if they can't work out how to fix it...
Old 25-11-2010, 10:53 AM   #8
Day-mow
rexnet
Day-mow's Avatar
Make sure there arent any nicks in the wires where you've worked. Are your joins to the speakers from the loom clean. - to - + to +
failing that. Back to manufacture for repair. Just double check all the connections on every thing is all I can think of.
Assuming your running 4 speakers?
Old 25-11-2010, 11:21 AM   #9
T3man
T3man's Avatar
The protection circuit cuts in when it registers incorrect load from the speakers. Or no load at all. Check the speaker requirements for the HU against the speakers in the vehicle. For example the HU might require 4 ohm speakers and the ones you have might be 16 ohm.
Old 25-11-2010, 01:38 PM   #10
TK-421
Problem sorted. it is the drivers door speaker, the piece that the wires plug onto has seperated from the speaker body. i can see now how it was intermitant on the factory deck as it is able to move and short out.
once again a big thanks for the replies. much appreciated.
