Old 01-09-2010, 04:57 PM   #1
GasoLane
Former BTIKD
GasoLane's Avatar
Default Seat belt replacement and Floor mat clips.
The Barge will need a new drivers side seatbelt before long. Has anyone here replaced one?
If so......
How much? ...I'm guessing only Ford dealers would keep them and how hard are they to install...... Don't even think of saying they're cheap at a wrecker!
Secondly, the clips that hold the front floor mats down have fallen apart. Can these still be bought? And, no I haven't rang our local Ford dealer yet, just thought I'd ask here first
Old 01-09-2010, 05:23 PM   #2
The Monty
Just slidin'
The Monty's Avatar
I only know prices from the wreckers, around $70-110 each!
I dont know Ford prices unfortunately.
I do know that they arent too hard to install, a bit fiddly, just have a torx bit set, a ratchet, a socket set, and a screwdriver set. Be patient, write down how they come out, take pictures if you can so you can go back to when putting them back in. You should be able to do them in about 10-15minutes each. Except the one in the centre of the back seat. Only way I could get one out at the wreckers was to hack the parcelshelf apart with whizz snips, lol.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 01-09-2010, 05:50 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Serious monty? I bagged one for my white AU1 last year for about $30. Uninstalled it myself, of course.
Yeah it's pretty simple Gaso, just take off the plastic cowling that covers the height adjuster, unbolt it from behind there and unbolt it from the floor and out she comes. Installation, surprisingly, is the reverse.
Old 01-09-2010, 05:59 PM   #4
GasoLane
Former BTIKD
GasoLane's Avatar
I take it they come with another plastic cover?
Old 01-09-2010, 06:00 PM   #5
mik
mik's Avatar
i asked how much a drivers side seat belt was a while ago, my retractor is getting a little lethargic at times (like me), sorry i don`t remember the figure, i do remember clutching my heart momentarily and thinking i`ll let that one go for a while longer, but i think it does come with the pillar cover(but i could be wrong) which gets a bit ratty anyway so its prolly not that bad.
Old 01-09-2010, 06:51 PM   #6
The Monty
Just slidin'
The Monty's Avatar
Yeah, thats the best prices I could get from a wreckers. Wacol Pick a part on the other hand, $49 all you can carry, I got 5, plus a plethora of other parts.
Old 01-09-2010, 07:10 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
I was hoping this is the case as there's no way to get the belt through it that I can see.
I see no one has any idea on the little clips for the floor mats....bugger.
Old 01-09-2010, 07:31 PM   #8
DW260
DW260's Avatar
I replaced the drivers-side belt not long ago. Auto stores wanted abotu $350 for a new one but I got one from FTG for about $70, including freight.
Just need the torx bit, and there is no requirement for a new pillar cover.
It's extremely intuitive, and very simple - Just like Mr Hardware has stated.
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2010, 07:43 PM   #9
mik
mik's Avatar
oh it looks like spares has led me up the garden path then with the cover(sorry Gasolene :( ).
Old 02-09-2010, 08:17 AM   #10
whiskers
gone fishing
whiskers's Avatar
here you go gasolane this is what I used to refit my seat belts changed over from the original s1 for the adjustable ones.
http://www.fordforums.com.au/showpos...1&postcount=78
it's very easy to do yourself
hope this helps
cheers
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2010, 03:17 PM   #11
whiskers
gone fishing
whiskers's Avatar
also remember seeing some after market ones in my local repco store a couple of weeks ago just over the $100 mark I think
Whiskers
Old 03-09-2010, 11:05 AM   #12
GasoLane
Former BTIKD
GasoLane's Avatar
Thank you O Whiskery one.
Old 03-09-2010, 05:37 PM   #13
whiskers
gone fishing
whiskers's Avatar
my pleasure here to help when can
Whiskers
Old 04-09-2010, 06:29 PM   #14
GasoLane
Former BTIKD
GasoLane's Avatar
hope this helps
cheers
Having had a closer look at these pics (the last photo in particular) and then the plastic cover in the Barge there's no way the belt will fit through the adjustable slot.
Looks like I'll be buying a belt already fitted with a cover.
Old 04-09-2010, 06:51 PM   #15
DW260
DW260's Avatar
Trust me, it does fit through. Once you remove the B-pillar trims, you'll see how.
Old 04-09-2010, 07:09 PM   #16
GasoLane
Former BTIKD
GasoLane's Avatar
Um, I don't see how. If you compare my belt with the one in the link that Whiskers sent there is a major difference where the belt goes through.
I have only about 2mm clearance. The plastic part that the belt actually goes through seems to be missing from the pics in the link.
Old 04-09-2010, 08:20 PM   #17
Bobman
Regulator
Bobman's Avatar
The plastic part is attached to the belt assembly (seen as black in whiskers' pic, but white/beige in other AUs).
The bottom of the belt, where it bolts on the floor is the end that you slide through the B-pillar cover (just take the bolt out first).
You do not need a new cover.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2010, 08:35 PM   #18
GasoLane
Former BTIKD
GasoLane's Avatar
Aha! This is the bit that I thought it wouldn't fit through.
Thank you.
Old 04-09-2010, 08:42 PM   #19
Bobman
Regulator
Bobman's Avatar
No worries mate.
So you undo the bottom bolt on the floor, then carefully prise the B-pillar cover off and lower it towards the seat. Take that bolt out that you just undid and slide the belt through the cover. Then the rest is fairly straight forward.
Let us know if you get in trouble!
Regards
Bobby
Current Cars:
Previous Cars:
Old 09-09-2010, 06:38 PM   #20
wagonwheels
Does anyone know how to replace or retension the drivers side rear seatbelt in my Au 99. Do i take the rear seat out to get to it.
Thanks
wagonwheels is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 06:58 PM   #21
frd906
woops sorry ill edit that, miss read the post
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 07:00 PM   #22
frd906
Yep you have to take the rear seat out to get to the bolt on the floor, then just pop the plastic off where the actualll mechanism is it self, and just undo the bolts or the torx bolts,
Old 09-09-2010, 07:56 PM   #23
wagonwheels
Thanks being a total novice how do i take the seat out
Thanks
Old 09-09-2010, 08:02 PM   #24
frd906
the seat is clipped in so you grab the front of the seat on the bottom bit and gently lift it up and it should unclip and come out
Old 09-09-2010, 08:34 PM   #25
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Joys of the AU -- it just pops out if you lift it; unlike the EF, which you have to push and lift at the same time.
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 08:41 PM   #26
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
where do i get floor mat clips from i have gia mats and thay slide about in the well
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 09:20 PM   #27
EV1LXR8
EV1LXR8's Avatar
i wanna know about the mat clips aswel if anyone know about how to fix that problem i know that vy crappydoors have a clip thing on the floor and the mat has an eyelet on each 4 corners
EV1LXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 09:54 PM   #28
wagonwheels
Is the seat belt winding mechanism under the bottom of the back seat or do i need to take the back of the back seat off as well. Does anyone have a link they can post with pics or a manual of this.
Thanks again
Old 09-09-2010, 10:19 PM   #29
frd906
no, the mech is actually on the pillar behind the plastic trim,
Old 09-09-2010, 10:37 PM   #30
wagonwheels
so to get to the seat belt mech do i need to take the seats out at all or just take the trim off, is that easy.
Thanks
