Old 22-08-2010, 10:19 PM   #1
peedee
peedee's Avatar
Default Gearbox problem on 09 focus
A friend of mine was telling me about a problem that he has with his 09 focus 5 speed manual that ford cannot reproduce or fix.
The problem is intermittant that when changing down from second to first mainly and ocassionally from third to second it clashes gears, now this guy has never driven autos and ford have checked the clutch and state there is nothing wrong there, it has done it from new, it sounds a bit like synchros to me or a mis-machined cog that only grabs occasionally as maybe having a tight tolerance that it meshes when engaged earlier in its rotation but just occasionally tries to engage on this tight cog, just some of my theories
Just wondering if anybody had a similar problem tried to search last night but could not find anything
Thanks People
peedee is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2010, 08:13 AM   #2
20focus05
I wanna XR5
20focus05's Avatar
Do you mean this guy has not driven manuals?
I have been driving manual cars for most of my life, I have cruched the gears a few times(mainly going down gears) in our focus by sometimes just being a bit lazy with the clutch.
If this fellow has not driven manuals before his foot may well not be in sync with his hands yet. Hope this does not sound I am bagging this fellow out.
These manual gearboxes are one of the strongest FWD boxes.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2010, 09:56 AM   #3
Mainlube
Mainlube's Avatar
May be as simple as a different oil.
It's hard to find a new manual car today with the correct oil on the gearbox.
They're missing the boat a little being text book worriers and following each other.
Often doesn't make allot of sense in the real engineering world.
Steve
MainLube - Extreme Lubricants For Overdriven Machinery
Mainlube 175 Synthetic Race Oil SAE 10w60 (engine)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff)
www.Mainlube.com.au
Mainlube is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2010, 10:04 AM   #4
REDDYZ
REDDYZ's Avatar
I dont know what kind of shift linkages Focus has but it can be linkages too if they are adjustable. On Renaults this is a common issue.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2010, 10:24 PM   #5
peedee
peedee's Avatar
No this guy has never driven an automatic at all only ever manuals
so no problems with using box, ggod point about the oil consistancy and also the adjustments, though as it only happens intermittantly I think the oil maybe the first to try
Thanks
Old 02-09-2010, 05:01 AM   #6
6T
Now a turbo man - sort of
Steve
What do you recommend then, Steve? Gearbox oil opinions from us mortals are about as hotly debated as engine oil.
White XR5T with Blue 11s
6T is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2010, 08:41 AM   #7
Mainlube
Mainlube's Avatar
May need a little help with this, what does the Handbook / Manual say the gearbox should take??
This lets me know what viscosity I can get away with (the higher the viscosity providing an better film strength resulting in less wear)
There is a trade off here protection verses no noise verses smooth change.
Get all these parameters correct we will have a quite smooth changing manual transmission that should perform for a couple hundred thousand Klms.
Steve
www.Mainlube.com.au
Old 02-09-2010, 08:58 PM   #8
20focus05
I wanna XR5
20focus05's Avatar
From Valvoline
Manual Transmission
HEAVY DUTY SYNTHETIC GEAR LUBRICANT 75W-90
Valvoline Heavy Duty Synthetic Gear Oil is specially formulated for heavy duty manual transmissions, differentials, and transfer cases operating in severe service applications (temperature extremes, extended drain intervals, etc) and requiring an extreme pressure API GL-5 gear lubricant. It is engineered from premium synthetic base stocks and select additive chemistry to provide extended protection from wear, rust and corrosion, heat and oxidation.
Service Refill Capacity: 1.9 Litres
The MTX-75 is said to be one of the strongest FWD gearboxes.
People have also reported that if non ford oil is used it can feel notchy.
Old 03-09-2010, 02:10 PM   #9
Mainlube
Mainlube's Avatar
With the info provided above I would recommend the Mainlube 154 Synthetic Solid Boundary E P gear Oil SAE 75w90, not the 75w80.
As the vehicle calls for a 75w90 and not an ATF there should be no gear change issue and best protection as 75w90 is a little thicker than the 75w80.
If there was any change issue I would swap to the 75w80 free of charge, would be a "suck and see" this one.
Steve
www.Mainlube.com.au
Old 05-09-2010, 03:29 PM   #10
6T
Thanks mate, question answered.
