Old 28-05-2010, 10:50 PM   #1
casabonka
You can call me Chris
casabonka's Avatar
Default Sub Help
Gday all,
I have a completely stock stereo in my Focii, and have just picked up a sub from a mate who pulled it out of his car b4 it went to the wreckers. Its a Blaupunkt ODsb 8000A Active Subbox.
Apparently it doesnt need an amp, just needs power (obviously) and the remote cable from the head unit.
Q is, how can I hook this up, and am I wasting my time. I cant find anything other than price reviews online about it.
Its One of those things I grabbed and then thought.. "hmm can I use it, or will it collect dust like everythink else at home"
Thanks in advance for the help
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2010, 12:17 PM   #2
photn
AFF Post NAZI
photn's Avatar
there are a number of ways it might work,
now i havent searched for that particular model and i dont know what ur friends setup was.
He may of been running it directly off the HU in his car. Was he using an aftermaret head unit?
Now to connect it, making the assumption it has an in build Amp, what you need to do is buy yourself a LPF - Low Pass Filter - About 20 buck roughly. then wat you do is find some speaker wires from your rear set of speakers if you could (could always locate them off the HU if you wish) run them through the LPF and into the sub.
The LPF will ensure that you get Bass from the sub not trebble.
Power wise you will need to buy yourself a 2ch wiring kit from any audio place, connect the power to the battery and then more than likely wire it through the rubber gromet in the firewall and up to the sub.
Keeping in mind that this is all based on the fact that it has a built in AMP.
Old 31-05-2010, 04:09 PM   #3
casabonka
casabonka's Avatar
That sounds exactly what his set-up was. It was a standard head unit (Commo).
Do I need to split the rear speaker cable without cutting right thru it, or is that what the LPF does?
Will head down to Strathfield car radio over the weekend and get the bits and peices!
Thanks for the help!!!
'06 LS Focus Hatch
-Tinted Windows
Old 01-06-2010, 08:22 AM   #4
photn
AFF Post NAZI
photn's Avatar
yes you will probably have to split the cables and cut into them,
whilstyour at strathfield take the sub with you and ask them. if it was a standard HU you want to be making sure it has an amp for best performance, otherwise it might sound quite dull.
Old 01-06-2010, 09:12 AM   #5
leakey
leakey's Avatar
Can you get your stereo out?
Try this - (might only be for the SONY unit, but worth checking)
Leakey
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2010, 09:25 AM   #6
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
Scratch that. Leaky it's the wrong diagram for the head unit in the new focus.
Old 01-06-2010, 03:18 PM   #7
leakey
leakey's Avatar
Bugger! Try this link, should be in there somewhere -
http://www.tehnomagazin.com/Auto-rad...-Connector.htm
Old 01-06-2010, 06:31 PM   #8
casabonka
casabonka's Avatar
Thanks heaps for the help, and thanks Leakey for going to the effort of finding those diagrams, but that is all waaay to difficult for me :P
I used to sell Home AV gear, and can hook that up blindfolded, but when it comes to cars im too nervous about touching it!
Let you guys know how I go at strathfield!!
'06 LS Focus Hatch
-Tinted Windows
