Old 19-05-2010, 11:10 AM   #1
KYSBF
Default 79 series 'cruiser
I'm looking to buy a 2000 Landcruiser ute. N/A diesel, 187000km from Taroom.
Any ideas of inherant problems or anything i should look for?
I know this is a Ford forum, but am asking all I know for their input.
thanks
KYSBF is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 12:25 PM   #2
redxm
64 Deluxe 4 door
redxm's Avatar
non turbos have ******** gearboxes. expect to rebuild it if it hasnt been done already.
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is online now   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 12:41 PM   #3
excopau
Default hey
I second that about the gearboxes, up north hear they make them live a bit longer by changing the gearbox oil when they change engine oil, toyota in there wisedom made the box stronger but halved the oil amount in gearbox, thats why they stuff up because oil goes crappy.
excopau is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2010, 08:01 PM   #4
naddis01
naddis01's Avatar
How much power would an NA diesel have?
naddis01 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2010, 08:45 AM   #5
redxm
64 Deluxe 4 door
redxm's Avatar
Not enough (about 130hp)
you could buy this one http://www.titanmotorsports.com/to1fzenpr1hp.html
XM Deluxe
FG XR50
BA Pursuit Ute
Old 21-05-2010, 09:29 AM   #6
super-xr
Ford to win!!
super-xr's Avatar
Dont buy a NA deisel. They are gutless and use TONS of fuel. If you cant get a factory turbo then get an aftermarket setup.
1998 AU1 XR6. Raptor Supercharged. 271 rwhp.
super-xr is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2010, 12:17 PM   #7
kypez
kypez's Avatar
97 KW on the 100 series... think they are a similar donk in both. 4.2 litre N/A
My Ford Family...
2014 GT-F, Manual, Kinetic with Black Stripes
2021 Mustang Mach 1, Manual, Velocity Blue
kypez is online now   Reply With Quote Multi-Quote with this Post
Old 21-05-2010, 07:47 PM   #8
Interceptor
HSV - I just ate one!
Interceptor's Avatar
only problem with looking for a turbo is they're a fair bit dearer.....
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2010, 07:52 PM   #9
InfernoSR
Sales Representative
InfernoSR's Avatar
not a huge amount of problems have come across my desk so far (work for toyota in the parts department), just regular servicing, and repack the wheel bearings every 40k...
Old 21-05-2010, 09:18 PM   #10
Green X
Lets see they are about the most solid 4WD ute you can buy. the 1Hz (4.2 diesal) will push out a easy 400,000km, don't know about this gearbox stuff, it may be weak, but with the 1hz pushing the gears you will only brake it if you abuse it.
I'm not a Toyota fan but the early Crusers and Hilux's are about as solid as they come they just keep on ticking. I just did 1650km in my 97 Hilux in 2 days, it's got 225,000km on it and at 110km/h the old hilux is pushing 3600RPM... Didn't use any oil didn't miss a beat the hole way, engine fires first tick of the starter.
FPV GS ute 5.0 S/C
Twin 3-inch, pacemaker headers
Green X is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2010, 05:58 PM   #11
KYSBF
Cheers for the replies, comments duly noted, ideal ute is a new V8, but way too dear. But I guess if your prepared to spend that sort of dough I could just keep the 45 and throw this sick piece of gear in it!!!
Old 22-05-2010, 07:02 PM   #12
Aulpgute
From first hand experience i second all of the above comments. Scary slow, scary thirsty, first sign gearbox is failing is it dropping out of 5th into neutral randomly of its own accord. Beg borrow or steal the extra for the factory turbo and go twice as quick with less fuel. Awesomely tough vehicle, great brakes etc etc. Good quality aftermarket shock make them ride lots nicer too
Aulpgute is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2010, 08:00 PM   #13
eb2fairmont
Hear hear!
The gearboxes are weak, but spend the extra on the later model 4200 TD. You'll get a 2" longer cab and front coil springs. Easy picked by the 6 gauge cluster with volts, fuel (x2) temp along with tacho and speedo.
eb2fairmont is online now   Reply With Quote Multi-Quote with this Post
Old 22-05-2010, 09:25 PM   #14
WiggyMK2
WiggyMK2's Avatar
The last of the 4.2 litre turbo diesel models were brilliant. Plenty of grunt, reasonably quiet (for a diesel) and don't have the oil consumption issues of the late model diesel V8s. I would save money and aim for one of these eventually.
WiggyMK2 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2010, 11:41 PM   #15
dave351cid
playing in my big shed
dave351cid's Avatar
the $$ you spend on the extra repayments for a turbo cruiser will be nothing when compared to the $$$$ you spend on extra fuel in the NA model.
the NA at worked used more then double the fuel that the turbo does.
and the NA are gutless as.....!
but on the plus side the NAs have better crawl capabillity, eg for driving slowly through rough stuff . the turbo at work idles too fast and wants more revs or will stall where as the 4 year old (200 000km) NA (which has just been replaced with a new nissan) would idle very low and just keep plugging on up a hill.
we had no probs with the gearboxs or diffs but the handbrake rarely worked ( but that could have had a bit to do with the mechanic who serviced it )
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2010, 08:04 PM   #16
roadrage77
good luck with your search
roadrage77 is offline   Reply With Quote Multi-Quote with this Post
