Old 18-05-2010, 09:03 PM   #1
fernsantos
Default Au I6 Overheating With Aircon On
This as happen twice with my car both times when I have the aircon on.
The first time I was in traffic with the aircon on and I noticed the temperature starting to climb.I pulled over turn the aircon off and the temperature went back to normal.
Today as it was raining I turned the aircon on in traffic to defog the windows the temperature started to climb as well as soon as I turned the aircon off it went back to normal.
Any ideas will be much appreciated on what the problem might be and the solution.
Thanks
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 11:54 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
When it's starting to overheat, get out and check if both thermo fans are running or not.
Old 19-05-2010, 12:12 PM   #3
fernsantos
Thanks I will have a look if one or both of the fans aren't working what could be wrong and is it expensive to fix.
Old 19-05-2010, 01:25 PM   #4
adumb
FG G6ET
adumb's Avatar
Had a similar problem. turned out someone before I owned my car had disconnected the thermos buy just yanking on the wires and snapped them, so it was an easy fix
adumb is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 02:06 PM   #5
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Overheating - is the failsafe system intervening or is it just via the gauge you think its overheating? If it's genuinely overheating (ie to critical levels) the computer will start cutting power to your engine.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 04:38 PM   #6
fernsantos
Yes that's what happened both times no power to the engine due to the temperature
Old 24-05-2010, 02:41 AM   #7
Mechan1k
Mechan1k's Avatar
Usually though the failsafe kicks in when the needle actually hits the red (and that's about the 135 deg C mark too.
I'd be checking the relays for the thermos for sure. I'd also be checking the remainder of your cooling system out as well ... just to be on the safe side.
Old 24-05-2010, 04:00 PM   #8
illusivedreams
thermo fan for me thanks.
Had same issue.
Au Falcon Ute S2 2001
Lowered on Kings with Bilistien Shocks all round
2.5inch cat back
K&N Panel Filter
FG XR6 17" Rims 245/45-17 tyres
XR6T Snorkle
BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads
Tow bar
Transmission Cooler
illusivedreams is offline   Reply With Quote Multi-Quote with this Post
