Old 08-05-2010, 10:16 PM   #1
TK-421
Default Factory clock into AU1 Forte.
Hi all, i would like to add a factory clock into my au1 Forte and was wondering if there is much involved in wiring and the plastic surround?
thanks.
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2010, 10:24 PM   #2
Kryton
Kryton's Avatar
I wanted the same thing when in my 2000 S1 Au when it was just 1 year old.
Took it to Ford, bought the clock for $47 and left it with them.
8 hours later the clock is still sitting on the seat and their response was that the Forte did not have the proper wiring for the clock so it cant be done.
They suggested an Auto electrician could make the loom and make it work but it would void my warranty.
They did say however, that early AU1's, already had the loom there, ready to use, but it was deleted lator on in the first series.
The place where the clock goes, just clips out.
You could remove it and have a look to see if the wiring is there.
If it isnt, you could probably get the correct loom from the wreckers.
It is all plug and play with the correct loom.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2010, 10:54 PM   #3
TK-421
i just noticed there is a small removable cover where the clock sits, i popped it off and it is moulded for the clock to fit, will have to wait till morning to check if there are any spare plugs in there.
thanks.
Old 10-09-2010, 10:00 PM   #4
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Would anyone know if the '98 models would have the loom? I've tried looking in the past, but haven't had a massive look for it. Cheers.
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2010, 10:08 PM   #5
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
my dec 98 has the loom there for it so i fitted it u must get a S1 clock with the black back with orange text
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2010, 10:11 PM   #6
Travisty FTT
I've already got the S1 Clock (I also snipped the loom from the donor car), I just haven't been able to find the loom in mine. Was it hard to find in your's, or was it obviously sticking out?
Old 10-09-2010, 10:22 PM   #7
POELWYK
POELWYK's Avatar
mine was looped up at the back i just pulled it and it come up
2001 AU Falcon
Old 10-09-2010, 10:32 PM   #8
Travisty FTT
Cheers Poelwyk; I'll check mine out in the morning and have a "Woman's Look" for the cord. Hopefully I'll find it.
Old 11-09-2010, 10:28 PM   #9
Travisty FTT
My AU doesn't have the wiring for it. I do however have the loom; would it be as easy as running some wiring to the memory wire in the stereo to keep track of the time and then to the ground and to the positive?
Old 12-09-2010, 09:14 AM   #10
fourl6
AU Falcon Man
fourl6's Avatar
the clocks backlight is off when the cars off, on when the cars on and dims when the lights are on, the actual clock is always displayed...
hope that helps you wire it up...
Cheers Cam
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2010, 10:16 AM   #11
Travisty FTT
Cheers Cam
Thanks Cam, working from that information (which I didn't take into account previously), I should still be able to use the stereo wiring to do all this as the standard radios dim as well. Fingers crossed it will work out. =)
Old 12-09-2010, 10:52 AM   #12
falcon oath
falcon oath's Avatar
my august 98 has the loom for the clock it was tucked back and taped up , the loom should be there , hope you find it
falcon oath is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2010, 11:10 AM   #13
Travisty FTT
Falcon, how obvious would you say your's was to see? DId you really have to have a poke around to find it in there, or was it just a lump taped with electrical tape that was easy to notice?
Old 12-09-2010, 06:34 PM   #14
falcon oath
when i first had a look i didnt think t was there , it was up the back ,
took the radio out and the ash tray undid all screws and then unclipped the facia , took the tape off and then pulled the loom forward , only problem was that i thought a s2 clock would fit , but they have different plugs ,
still havnt got a series 1 clock ,
series 2 clock for sale pm me if anyone is interested , $10.00 plus post
Old 12-09-2010, 06:36 PM   #15
falcon oath
btw what year and month is your S1
Old 12-09-2010, 07:43 PM   #16
fourl6
AU Falcon Man
fourl6's Avatar
i just wired up my old clock in my dads rodeo, got it working same as factory
black - earth
yellow/black = constant 12v
purple/red = either illumination or ignition (cant remember)
white = either illumination or ignition (cant remember)
the clock worked with just the constant and neg were plugged in but the light wouldn't work unless both the others were connected
edit, thats on a S2/3 clock, i assume a S1 is the same
Cheers Cam
Was
