Old 27-03-2010, 05:01 PM   #1
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Default Front jack stands
Hey guys. When you're jacking the front of your AUs - assuming you jack at the designated point - where do you put your jack stands? The main chassis rails? I'm scared to use the crossmember after stories of cracking.
Looks like it's my turn to do the front hub shuffle.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2010, 08:35 PM   #2
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Chassis rail, about level with the A-pillar. You are correct about the cross member cracking, so leave that alone.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 27-03-2010, 10:40 PM   #3
blownv8au
Pro Street Au Ute
blownv8au's Avatar
i put the stands under the chassis rail at the a pillar where the metal is overlapped. and i only ever jack from the lower control arm as close to the wheel as possible after using the jacking points on my first xd and having my sill cave in lol.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
