Old 21-03-2010, 05:26 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default AU2 Ghia Diff. Is it a 3.45 LSD?
Hi Guys,
Just wondering if an AU2 Ghia VCT 6 will have a 3.45 LSD as standard?
Thanks,
Justin.
Old 21-03-2010, 05:30 PM   #2
sd1800
I believe that yes, the 6cyl is 3.45 and V8 is 3.23. V8 isn't LSD, not sure about I6
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2010, 05:47 PM   #3
private9
private9's Avatar
Non LSD huh, lame!
Old 21-03-2010, 05:49 PM   #4
Stattic
Stattic's Avatar
i think LSD might have been an option with the VCT ghias
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2010, 09:30 PM   #5
Jimmyd
IIRC was not available as a stand alone option on AU VCT Fairmont Ghias - had to order the Tickford Sports Supsension Option to get LSD
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2010, 10:19 PM   #6
SSVPom
Formally FairmontPom
No LSD in the VCT, and not the V8 either IIRC...
Sports suspension did not add the LSD either, just XR6 spec Tickford shocks and lower springs (and an engraved Tickford compliance plate under the bonnet !)
1998 XH Falcon V8 S Pack, white, couple of dents. Bogan project
2024 Everest Platinum
SSVPom is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2010, 10:27 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Check that because it might actually be 3.23?
2024 F150 XLT
Old 23-03-2010, 11:34 PM   #8
GK
Walking with God
GK's Avatar
I thought Fairmonts got 3:23 and Ghias got the 3:45.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 24-03-2010, 09:15 AM   #9
BIGJB
BIGJB's Avatar
Both the VCT S1 and S2 Ghias I have owned had 3.45 and LSD so I figured
it must have been standard..... or was I just lucky???
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2010, 08:11 PM   #10
sikford
THE Fairmont Ghia 75th
sikford's Avatar
my ghia is 3:45 LSD but as stated above i thought that was how they came unless someone knows otherwise.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2010, 09:48 PM   #11
Jimmyd
Gee, I wonder what this little factory fitted item is then....
99 AU1 update Fairmont Ghia VCT with Tickford options
NB AU1 Tickford Suspension (basically the XR6 VCT package) was packaged with the 17" Alloy Wheel Option...
Memory was correct, listed as Not Available for IRS in the brochure...
Here
But listed as option with Sport Suspension in the AU2...
Here
And 3.45 was std ratio in the Fairmont Ghia VCT
Here
James
Old 29-03-2010, 10:47 PM   #12
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
GK
Right you are GK, mine is a 3.45 however the LSD was an option, at least on the s1 afaik
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2010, 02:48 PM   #13
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
My AU Fairmont Ghia VCT doesn't have LSD.
I thought AU Ghias didn't get it because they got traction control which doesn't work with LSD thus why the AU XR6 VCT doesn't have traction control.
I wish the AU did have LSD but sadly I'm stuck with single spinner burnouts.
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2010, 10:53 AM   #14
private9
private9's Avatar
I got off my butt and poked my head under (hard work I tells ya!) and can now confirm that it is definitely a 3.45 single spinner.
Old 04-04-2010, 11:15 AM   #15
Jimmyd
AU Traction Control program works on difference in rotational speed for front wheels vs rear wheels - LSD would not be a factor in this calculation. The argument that Traaction Control & LSD don't mix was marketing hype at the time as to why the XR series did not get Traction Control - and no, I'm not making it up; I ran a Ford service dept in '98 when released and later moved in to selling them in 2001 while recovering from illness.
As per the post above the LSD is listed as packaged with Tickford Sports Suspension option in the IRD Fairmont Ghia Here ......
