Old 27-09-2009, 02:54 PM   #1
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Default How do I get the Fanbelt back on?
I had to replace my alternator, so I pulled off the belt, which was easy enough. Now I've changed units and have to put it on, but I can't see how you do it without having another person there to hold the tension on the belt.
I have a gregories manual, but it doesn't explain it too much very well.
Cheers.
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2009, 02:59 PM   #2
StealthAu
you need a 3/8th's drive ratchet with a long handle (or pipe over the handle).
Put the belt on every pulley except powersteering pulley, then push the handle towards the passenger side guard (turning it clockwise) and lift the belt over the p/s pulley.
Should also mention where the ratchet goes
on the belt tensioner (thing the 2 idle pulleys are attached to) there is a square cutout that the drive of the ratchet fits into.
Old 27-09-2009, 03:02 PM   #3
frd906
should have a picture of how the belt goes on on the bonnet, anyways
feed the belt through the tensioner and the other pullys but leave the belt off the power steering pump, so get your self in postion and pull as hard as you can to stretch the belt to get it over the power steering pully, leave the tensioner lose so you can do this, then redo the tensioner back up. easiest way my mate did it
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2009, 03:06 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. Would help if we knew what sort of car it is?????????????????????????????? Cheers MD
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 27-09-2009, 03:08 PM   #5
frd906
obvisouly if its posted in the au section is a au
Old 27-09-2009, 03:16 PM   #6
Travisty FTT
Ironically, its an AU Ford. Thanks for the help guys, I'll let you know how I go.
Old 27-09-2009, 04:23 PM   #7
foxtrot3
foxtrot3's Avatar
Hi Sorry I was looking in new posts but what stealthAu said is right. Cheers MD
Old 27-09-2009, 05:06 PM   #8
superroo
You can't stop the signal
superroo's Avatar
From the gregory's manual
Old 27-09-2009, 06:34 PM   #9
Mont5.0
Mont5.0's Avatar
^^ that pic works well for the 4 litre.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
