Old 06-09-2009, 08:59 PM   #1
Marlboro2728
Marlboro2728's Avatar
Default Focus Interior Light
Just bought a TDCi which is great except for it has no central interior light. I've seen the XR5's have one and I want to put one in as it is a pain with young kids in the back. Is there a roof mounting point or is it just attached to the roof headlining? :
Marlboro2728 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2009, 03:17 PM   #2
sumpPUMP
SUMPA's sedan
sumpPUMP's Avatar
try here
http://www.fordforums.com.au/showthr...interior+light
there is another thead of someone putting a dome light in the rear too but i cant find it
'07 sapphire black manual LT focus zetec sedan
6.5" alpine dvd player - alpine splits - response amp - alpine 12" sub - lovell's supalow springs - LV XR5 Focus wheels - Kumho KU31's - black leather - tint
sumpPUMP is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2009, 03:51 PM   #3
sumpPUMP
SUMPA's sedan
sumpPUMP's Avatar
or here
Old 07-09-2009, 06:04 PM   #4
leakey
leakey's Avatar
The older Ghia's had a light in the back.
I've just picked up some vanity lights for under the visors, and will be putting
some lighting in the back too.
Either the Ghia light, centred towards the back of the roof lining, or two small
lights either side of the car, in front of the grab handles. (sourcing these from UK)
Here is a wiring guide that shows wiring in the roof. Might help you make a decision
on what to do.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 09:16 AM   #5
Marlboro2728
Thanks for the replies. I will try to source a focus front light and position it in the middle above the rear seats as I have the side airbags. I will have to run the wiring from the front light above the headlining. Let you know how it goes. :
Old 08-09-2009, 10:41 AM   #6
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
your the diagram master Leakey. Where do you find all this stuff? I've wondered where the wires are in the roof were.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 04:13 PM   #7
leakey
leakey's Avatar
Friends in high places.... : )
Old 09-09-2009, 07:23 PM   #8
dave_vic_ozz
I had a look in my bags of bits but I must have left it in the car for the wrecker to recycle.
It is always the way.
You could just add to the wiring from the light you have. You will need to remove the sun visor screws and the trim around the door. Take care as there is a fair bit of glue holding it all up. The key transponder is near the lamp on the left side so take you time. The wires are stuck to the lining too and you may be tempted to pull on them. Better to get to the wires from the light itself and push a string down to your new hole with a bit of plastic strip. Drag some wire through and join it all up with minimum disturbance to the lining. I have never needed to pull the lining off the roof more than the front edge so unsure what is much further back.
The other way is to find the wires in the left A pillar. Colours in the switch should be the same but there is a join in there somewhere and the colours change IIRC.
These are the ones to avoid.
Dave D.
dave_vic_ozz is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2009, 09:33 PM   #9
leakey
leakey's Avatar
Awesome answer. Great techy.
Old 18-09-2009, 09:31 AM   #10
dcyl1973
Black Turbo Focus
Just fitted an led light to the rear of my TDCI focus.
I got a circular 11led light from the local electrical wholesalers and mounted the flat led light under the passengers rear grab handle. I then ran the cables above the roof lining to the existing front light, connected via spade terminal crimp lugs to the light.
Made a huge difference to the back seats when trying to get the kids in/out at night.
dcyl1973 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2009, 03:19 PM   #11
Marlboro2728
That looks great, it even matches the headlining color.
Old 18-09-2009, 09:03 PM   #12
Marlboro2728
Still thinking about these lights, not sure if I can put the lights near the grab handle as I'm worried about the side curtain airbags. :
Old 22-09-2009, 01:19 PM   #13
dcyl1973
Black Turbo Focus
Cool
The side curtain airbags are not interfeared by this light they come out beside the edge of the roof lining, if you pull the rubber back and pull the lining back slightly you will see them there.
Because this type of light is surface mounted it's only the cables going into the lining.
