13-08-2009, 05:48 PM | #1 | ||
Shame Holden, Shame
I reset my ECU according to instructions on aufalcon.com, then took it on the 5 minute drive with varying throttle positions.
When reaching corners and/or braking the car looses revs and sometime cuts out (happened 3 times in 5 mins), steering goes dead too as result. A few lights come on in the cluster, one being the battery and the other the teapot thing with drips of water coming of it. (when car turns off). I gave it maybe half a dozen bootfuls aswell as some light 2,000 rpm work on my drive just then. What on earth is going on?? Everything was 100% before the reset! Thanks guys!
Essendon FC '11 EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer| METALLICA |
13-08-2009, 06:02 PM | #2 | ||
Resident AFF detailer
Had exactly the same thing with my car when I last reset my ECU.
It's just the computer learning when it needs to boost the revs to compensate for added strain on the engine (a/c, demister/ power steering etc) at different times. If anything, just continue to idle the car in the various positions, as the aufalcon.com website says to immediately after you've reset the ECU - I found that helped eliminate the engine cut-outs similar to what you're experiencing. Give it 100kms and it shall all be fine again!!!
13-08-2009, 06:09 PM | #3 | |||
Shame Holden, Shame
So let me get this straight: The ECU resets after 40 mins of battery being cut out and the ac on off stuff is to allow the car to learn to boost the revs? Guess ill have to go for another drive then :evil3:
23-08-2009, 03:27 PM | #4 | ||
Did you get this sorted? Did it make a difference to fuel consumption?
23-08-2009, 05:36 PM | #5 | |||
23-08-2009, 06:49 PM | #6 | ||
Smile
The eecv computer has many startup maps. Your ecu has learnt the wear and tear into you tune and resetting has erased this. The ford computer weakness is that it cannot go back to the before tune after a reset.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
23-08-2009, 09:52 PM | #7 | |||
