Old 09-08-2009, 08:46 PM   #1
51OAU
51OAU's Avatar
Default Diff is wrecked.
Well my diff has just started making some clunky noises when underload. Its a loud bang but im not sure what it could be, Thought it could be the handbrake as its fairly loose. Anyone else no what it could be.
51OAU is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 08:56 PM   #2
BLOWNXR8UTE
345rwkw BLOWN XR8 UTE
BLOWNXR8UTE's Avatar
sounds like a cracked carrier to me. The bang would be the spider gears mashing and not meshing.
BLOWNXR8UTE is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 09:04 PM   #3
51OAU
51OAU's Avatar
would u be able to hear that all over the car? i can only hear it come threw my left ear. not my right. If someone sticks there head out the left side of the car they say its the rear, stick your head out the right hand side they say its sounds like something on the other side.... hmm its weird and getting to me cause the lsd is barely 5000km old.
Old 09-08-2009, 09:08 PM   #4
BLOWNXR8UTE
rip the disk off and check your handbrake theory, it could be that now you have said that, hopefully your right, for ya pockets sake!
Old 09-08-2009, 09:10 PM   #5
51OAU
51OAU's Avatar
yea my mate said something about the handbrake isn't that tight, so the "something" is moving around and causing a bang. So adjust the handbrake tight and see what happens?
Old 09-08-2009, 11:19 PM   #6
51OAU
51OAU's Avatar
The clunk is also not constant, its only every so often, its not like clunk clunk clunk as i drive just every so often, normally when i put my foot down it do it
Old 09-08-2009, 11:29 PM   #7
mik
mik's Avatar
universal joint?
Old 09-08-2009, 11:38 PM   #8
51OAU
51OAU's Avatar
Originally Posted by mik
universal joint?
how can u tell there buggered?
Old 12-08-2009, 12:22 AM   #9
mik
mik's Avatar
universals can clunk around abit when they are badly worn (usually on a higher mileage car), while its on a hoist is easiest (and safest)to check them and driveline sloppiness, should`nt cost to much .
Old 12-08-2009, 12:39 AM   #10
51OAU
51OAU's Avatar
yea my bro thinks its the universal joint in the rear, so picked up 2 new ones today $26 each, so will be fitting them tomorrow see what happens.
Old 14-08-2009, 09:57 PM   #11
blackers10
blackers10's Avatar
my diff clunks.. it comes through as sloppyness if you lightly feather the throttle on and off you can feel it take up the slack and bang and the bang when it hits the other side of what ever its playing (each side of a cog tooth or somthing)
my tailshaft moves about 1/2" or more each direction if you spin it with the handbrake on and the car on the ground
not much help for your clunk.. but id see maybe if its even anything to do with the driveline.. may be a loose suspension bolt??
