Old 08-06-2009, 11:34 AM   #1
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Question Has the I6 got anything left?
Reading about the coming Direct Injection update for the Commodore (3.0L at first, who knows for the 3.6) of course made me think about the Falcon's trusty I6. If the Commodore gets a DI 3.6 litre V6 then the I6 will be out-powered (but not out-grunted) for the first time in years. Probably bring fuel economy improvements with it as well.
So where does that leave the I6? Not really knowing what Ford's long-term plan is for the engine (for argument's sake, let's just say it will be around until 2013) it could be anything, but I would imagine that any sort of investment in the engine of the level required to bring DI to the I6 would be out of the question I would have thought. It's an 'orphan' engine don't forget and Ford is strapped for cash.
I would have thought that the I6 in it's current guise would pretty much be at it's power ceiling (I'm talking about the n/a version here). But there could be some fuel efficiency improvements still to come. Electric waterpump and power steering? Engine block pre-heaters to cut down the warmup times? Cylinder deactivation (which it already has but as an overheating failsafe)? Stop-idle function?
Would Ford even bother trying to compete? The engine may be down on power compared to the 3.6 DI but still would have more torque. And then of course, there is the turbo motor for performance and premium applications. But being green is the thing these days and if they don't compete at least on a fuel consumption level, they'll get left behind.
Discuss.
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 11:56 AM   #2
ltd
Force Fed Fords
ltd's Avatar
No, with DI ford will have an even greater amount of power and better fuel economy. Look for a power output of about 220-225kw and fuel use down to about 8l/100klm on the combined cycle. There's still heaps of innovations available and from what I've heard, most of them will be used once the Euro4 emmissions standards come in 2010.
Things like piston design, tolerances, compression ration, dual spark, lower idle rpm, more knock sensors etc etc can add to fuel efficiency and increase power.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 12:04 PM   #3
PepeLePew
Workshop & Performance
PepeLePew's Avatar
You'd assume Ford has DI on the cards if the engine still has a future?
Tis unfortunate that power numbers sell, torque is still too technical for Joe Q Public to wrap their minds around.
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1
A stereo that happens to have a XR5 wrapped around it
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 12:35 PM   #4
futura97
I thought ford was dumping the I6 in favour of a V6... And this was meant to be happening in the next couple of years?!
Edit - Article here...
Seems like holden are only going DI because ford where going to beat them to it anyway...
futura97 is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 12:47 PM   #5
Falc'man
You dig, we stick!
Falc'man's Avatar
The I6 as it is now would still out-torque the DI 3.6L V6. Come 2010 the standard I6 available in the base model Falcon will still be favoured as the best 6 cylinder on the market: in this range, of course.
There is one thing you cannot take away from the Alloytec, no matter what you throw at it; coarseness!
No, I6 will stay on. That's a very old article.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 12:52 PM   #6
futura97
learn something every day Have you got a link to an article about the changes they are making to the I6?
Old 08-06-2009, 01:00 PM   #7
Kieron
Holden are releasing a 3L DI/6 speed auto later this year, fuel economy is reported to be in the 9.5/100 range so i'd say 8/100 for a 4.0/6 speed auto Falc is a bit optimistic
futura, they reversed that decision and the I6 stays. Not sure what thay says about the unique Falcon but it wouldn't be surprised if it's a sign of the demise of the Aussie Falc.
Not sure Holden are going DI due to Ford, that V6 is GM's world donk so the decision would have been more to do with whats needed worldwide in the battered GM bunker.
As for the I6, DI and cylinder deactivation are the obvious next step as already mentioned.
IIRC the reversal decision was based on the Aus govt. throwing some money Fords way which will be used for the I6's upcoming Euro 4 compliance so i'm thinking a few software tweaks + peripheral components such as exhaust/cat con's and thats about it.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 01:01 PM   #8
XR Martin
XR Martin's Avatar
When the Alloytech came in 2004 it had 190kw, and the Barra had 182kw. When the Barra jumped to 190kw, the Alloytech had 195kw.
Now they are on equal footing with the 195kw FG.
So your comment on the Falcon being out powered for the first time in years isnt exactly accurate.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 01:01 PM   #9
Falc'man
You dig, we stick!
Falc'man's Avatar
http://www.fordforums.com.au/showthread.php?t=11241338
Old 08-06-2009, 01:02 PM   #10
Road_Warrior
Pity the fool
Given the cost involved with developing DI for the I6, I can't see it happening. Would be good, but...not tonight, Josephine.
Old 08-06-2009, 01:55 PM   #11
ltd
Force Fed Fords
ltd's Avatar
Mate, it is happening. The I6 can't make Euro4 without it. Further, the I6 plant is going beyond the previous 2010 close down.
Powered by GE
Old 08-06-2009, 02:04 PM   #12
Road_Warrior
Pity the fool
lol, all the I6 will be getting to pass Euro 4 is a revised catalyser and ECU calibration. It's not much. The Euro 4 changes were already drawn up when the decision was made to switch to the V6.
Don't forget, Euro 4 is all about tailpipe emissions. Fuel economy is a market driven thing.
Old 08-06-2009, 02:27 PM   #13
R-Design
Guess Who's Back?
R-Design's Avatar
"GoAuto understands the upgrade will focus on injection, calibration and exhaust, and company sources have confirmed the work will not involve moving to a direct injection system."
http://www.goauto.com.au/mellor/mell...257507000C2D46
R-Design is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 02:57 PM   #14
Fordman1
Fordman1's Avatar
No DI for the forseeable future unfortunately.
It's all about calibration, electronics and the exhaust system next year...
Fordman1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 03:10 PM   #15
Quicksand
Lucky, lucky bastard!
Quicksand's Avatar
could explain why Ford are looking at Liquid Injected LPG in the interim?
http://www.fordforums.com.au/showthr...&highlight=LPG
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue
2012 FPV GT-P 6spd Auto, Lightning Strike
Quicksand is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 03:16 PM   #16
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Dude, your figures are for the hi-po commodore six, not the normal one
the VZ of 2004 had 172kw where as the BA had 182kw
The VE of 2006 had 180kw where as the BF has 190kw
now the FG has 195kw
about the only time the commodore outpowered the falcon was in 1986/1987 with the 114kw VL vs the 104?kw XF.
Old 08-06-2009, 03:51 PM   #17
ltd
Force Fed Fords
ltd's Avatar
Yeah you're right, I was getting confused with the announcement I heard of the direct gas injection. Sorry.
Powered by GE
Old 08-06-2009, 03:54 PM   #18
Fordman1
Fordman1's Avatar
That Gas engine will be a ripper I'm sure .... :
Old 08-06-2009, 04:04 PM   #19
ltd
Force Fed Fords
ltd's Avatar
I agree. Hopefully the power output of it will be higher as Gas apparently has a higher octane than petrol
Powered by GE
Old 08-06-2009, 04:32 PM   #20
Road_Warrior
Pity the fool
Anyhoo, getting back on topic...
No DI in sight, what else could Ford have up their sleeve for the I6?
Old 08-06-2009, 04:42 PM   #21
Fordman1
Fordman1's Avatar
The LI Gas engine will be the "Ace" up Fords sleeve (It's NOT off topic), lets hope they can convince the buying public that it is something they should purchase.
Old 08-06-2009, 04:44 PM   #22
Dave R
Member
Technical Contributor: For members who share their technical expertise. - Issue reason: Valued contributor especially in the FG threads. Offers help and information to all. Posts are always in a positive manner.
Well without $$ there's not a whole lot Ford can do. The current powerplant is fine in terms of power and economy. Holden might just have the upper hand for the next few years.
If it's true that Ford is working on a diesel Territory, why couldn't they drop a diesel in the Falcon too?
Dave R is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 04:53 PM   #23
seXCmont
EcoBoostin
seXCmont's Avatar
save a lot of money on fuel and probably an excellent idea. the government already given out a rebate for turning your car to LPG would make sense if they through money Fords way to make the new I6 a LI Gas engine. LPG does burn Quicker than gas because of its higher octane. I think LPG is around the 104 mark compared to 92 of standard unleaded
seXCmont is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 05:04 PM   #24
BHDOGS
Ford ruined the I6 soon as they bolted a turbo onto it its skyline the second now with dyno queen whingers
Old 08-06-2009, 05:13 PM   #25
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
More like created a modern day classic.
Back to the thread...
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 05:54 PM   #26
FalconXV
FalconXV's Avatar
Put six polished throttle body manifolds on the side, Variable Valve lift, electric motors to take care of ancillaries,direct injection of course, desmodromic valves to reduce pumping loss, atkinson cycle function and lean burn highway function, let it scream its guts off; Since it's potentially nearing the end of it's life, it should go with a BANG! at least do this on an XR6 before the engine dies... (that reads like a 250kW, 430Nm, <8L/100km car to me...).
The engine doesn't have to die though, stranger things have happened and maybe Marin can convince Dearborn to keep it. Full Electronic Valve control should become mainstream through the new decade; I would love to see it on grampa's axe. Also CNG should be investigated and E85 ( since they can now extract it from tips, its the most sustainable option).Maybe even HCCi on an ecoNETIC version?
Even though Falcon now has a premium image, this is costing them fleet sales, so XT should be re-thought for cheapness of service, repair ( unpainted bumpers), CO2 and lower bottom line= Falcons used to cost less than smaller imported cars and their should be a spartan entry level model celebrating the purity of Falcon's fundamental virtues. Transit 2.4D/ 6 speed combo would work wonders.
In reality Ford Oz seems reluctant to make the radical changes necessary, they won't even bring in the electric Focus, which is utterly criminal (particularly when Hybrid Camry and Volt are coming).
To those who will condemn my post on the basis of irrelevant fantasy- to hell with you- the engine has alot of potential Ford will not exploit.
FalconXV is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 06:10 PM   #27
schnoods
schnoods's Avatar
Nothing left in the I6, its all been done.
Yet everyone kicks up a stink when they try to change it....
A philosopher is a person who finds a problem for every solution . :Reverend:
95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph
Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's
1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored.
schnoods is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 06:18 PM   #28
XR Martin
XR Martin's Avatar
I knew someone would bring that up..
Well the same could apply to the EA-EB1 then, and also the XFs
Base model 3.9L EA-EBIs had 120kw, VN/VP Commodore had 125kw
And im glad you brought up the XF, base model XF had 90kw (and 3.2L EAs) , VL had 114kw
Old 08-06-2009, 06:27 PM   #29
Lukeyson
Right out sideways
Lukeyson's Avatar
The thing is why change it ? for a cheaper end TQE (by that i mean it isnt competing with bmw etc) , nothing touches it IMO in performance and drivability
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 06:48 PM   #30
schnoods
schnoods's Avatar
Well Buick did change their straight 8 powered cars to the more compact V8, one day ford might think the same way...
Im not saying change it for changes sake, but a bit more development in an alternate engine, good things dont last forever...
Some say torquey down low, others say lazy up higher...
