Old 15-05-2009, 11:10 PM   #1
sikford
THE Fairmont Ghia 75th
sikford's Avatar
Default Removing airbag
It seems that there is 2 5star torx bit screws that need to come out, iis there any other way of getting these out? I went to bunnings and they dont seem to have them.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 11:12 PM   #2
ronwest
All Bran = Regular Member
The torx bits are hard to get - I got mine off ebay.
Some have had success using a slotted screwdriver.
Old 15-05-2009, 11:12 PM   #3
sikford
sikford's Avatar
i might add that i went to bunnings without thinking and bought the 6 star set only to find out they were a 5 point star and thats all they had
My Ride
My Build Thread
Old 15-05-2009, 11:13 PM   #4
ronwest
haha! I did the same thing, lol.
Six sided came in handy on my wife's previous eurocar so nothing lost ;)
Old 15-05-2009, 11:15 PM   #5
sikford
sikford's Avatar
haha, damn car, as i keep doing one thing i have to do something else on it.thats life i spose :P
My Ride
My Build Thread
Old 15-05-2009, 11:20 PM   #6
ronwest
yeah, but it's fun though
Here's a GK's tute showing the slotted screwdriver (or at least a bit that shows what it looks like)
http://www.fordforums.com.au/showpos...1&postcount=59
Old 15-05-2009, 11:23 PM   #7
sikford
sikford's Avatar
ill give it a go right now
My Ride
My Build Thread
Old 15-05-2009, 11:56 PM   #8
sikford
sikford's Avatar
gave it a try and managed to stuff 2 bits so i think ill have to hunt around for the tool unless someone has the right tool and would maybe come around to give me a hand so i can borrow it?just pm me.
My Ride
My Build Thread
Old 16-05-2009, 12:57 AM   #9
blownv8au
Pro Street Au Ute
blownv8au's Avatar
i bought a set from bunnings to ha ha, so i went to ford a mechanic there undid them for nothing. when you get them out put hex bolts in instead much easier next time and steering wheel can be removed with allen key 7 or 8mm i think instead of torx bit. good luck. preston
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 01:02 AM   #10
au^dude
au^dude's Avatar
What i did was cut an old screw driver. worked ok. I also have a steering wheel puller that you could borrow.
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 07:16 AM   #11
GS608
i know glenfords and bursons have them, pretty pricey though.
Old 16-05-2009, 08:38 AM   #12
bodes-sh
i clotted a screwdriver bit, one of those ones that goes in either a ratchet or t handle driver, didn't even really need to slot it, but i found with either a ratchet or t handle you can put more force into it and it comes out easier...
might be worth a try
Old 16-05-2009, 02:24 PM   #13
superroo
You can't stop the signal
superroo's Avatar
A slotted screwdriver works, but it may take a few attempts of breaking it to get it to work.
I brought a cheap screwdriver from the reject shop, and modified that. Does take a few goes though.
After I finished with mine I gave it to someone, and it broke first shot for them. So preserver and you'll get there
Old 16-05-2009, 06:30 PM   #14
mik
mik's Avatar
or if you have a dremel you can carefully grind a slot in the screws then take them out with a screw driver, then replace them with allen key type bolts
Old 17-05-2009, 01:55 AM   #15
sikford
sikford's Avatar
hrmmm, i will see if i can hunt one down when i go to the tool shop for some other bit this week, i wish i had one of them dremel's, they're good for lots of tasks.lol
My Ride
My Build Thread
