Old 02-12-2008, 10:09 PM   #1
Gonz
BA XR6T UTE - ANIM4L
Gonz's Avatar
Default AU UTE Diff RATIOS?
I want to change my Diff ratio, ive got an XLS V8 Auto, im sure it might have like a 2.9? in it now.
What Diff ratio options do i have for my ute? im after something around 3.7's? also what spline numbers do they come with? ill need a strongish set up and cant afford a 9" atm.
anyones help who may have the answer or experience with having changed there own ratio (info on road speed/RPM etc) will be much appreciated,
cheers,
Gonz.
BA XR6T"ANIM4L" UTE UNDER CONSTRUCTION!
WA Member of proUTES.com : we need more FORDS!!
CHECK OUT MY OLD AU UTES!! IN HERE!
CHECK OUT MY OLD FG UTE!! IN HERE!!
CHECK OUT MY LATEST BA UTE!! IN HERE!!
YOUTUBE POWERCRUISE VIDEO!! CLICK HERE!!
YOUTUBE INCAR VIDEO!!CLICK HERE!!
Gonz is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2008, 03:11 AM   #2
The Monty
Just slidin'
The Monty's Avatar
It would have 3.08's.
If you get different diff gear, dont get the cheap ones off Ebay, they are old and weak.
Your options are 3.23, 3.45, 3.73, 3.89, and 4.11's.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 04-12-2008, 08:56 PM   #3
Gonz
Gonz's Avatar
cheers...
whats better as i need to use this ute for a daily drive this coming year so it will see plenty of freeway driving, will the 3.89 be too much or should i just go with a 3.73??
what RPM will it have at 100km/h with either ratio?
i am a 4 speed Auto!
Gonz.
Old 04-12-2008, 10:19 PM   #4
StealthAu
Originally Posted by Gonz
cheers...
Gonz.
Firstly I'm pretty sure all utes got 3.23's from factory except the xr's which had 3.45's. On the highway at around 105k's I sit on around 2500rpm with 3.89's and auto
Old 04-12-2008, 10:38 PM   #5
schuldiner
positive the utes got 3.23's(except xr's) as thats what came in mine. i've just put in some 3.7's and i reckon my speed is out by about 15% and at about 110kmh i'm pulling 2,500rpm. this being an increase of about 300-400rpm(manaul) i couldn't see the 3.89's being more than another 50rpm. there is a calculator floating about i'm sure someone will pop in and give you a link. i purchased a new speedo gear for $12 from ford and the guy reckons every extra tooth on the gear is worth about 5-7% which sounds right as i was told to get the black gear which has i think 23 teeth as opposed to the grey gear with 21 teeth which is in my gearbox at the moment. i was told anything more than 3.7's in a non xr diff will involve modifications to the housing which will make it more expensive.
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2008, 09:38 PM   #6
Gonz
Gonz's Avatar
hmmmm, ill have to look into that!!
and yeh, i was going to ask about the speedo gearing, do they cater for 20" wheels?
cheers,
Gonz.
Old 05-12-2008, 09:48 PM   #7
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
What about LSD on an XLS? did it get the XR8 ratio?
Holden: If you cant beat them, buy them.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2008, 03:29 PM   #8
schuldiner
as far as i know the XR was the only one that got the 3.45's otherwise you would feel your buying an XR just for the different bodykit they need the slightly higher ration so they pull a bit harder. or at least thats how i've figured it. with the 20 inch wheels if you find the calculator thing i believe you input that as well. i dontk now for sure but i think 20's would throw your speedo out just enough to maybe compensate for 1 extra tooth on the speedo gear. the other option is to go to jaycar and buy a corrector box for about $50 someone posted a part number on here some time ago. otherwise i was told bya company i could buy what seems to be that same box for $250 so i figured even if i cocked up the $12 gear a few times it'd still be less than half the price i was orignally quoted.
see my ute here
AU parts for sale
Old 06-12-2008, 06:53 PM   #9
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
its easy to calculate, just take your rpm at 100 devide it by your diff gears, and then times it by the new ratio and it will tell you your new rpm at 100
So if your doing 1950rpm at 100kph with 3.23's
1950/3.23 = 603.72
603.72*3.73 = 2251rpm
603.72*3.89 = 2349rpm
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2008, 07:17 PM   #10
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Just got a quote from a diff shop in perth, to go from 3.45 to 3.9 and he said nothing about mods to diff housing, Said they had done quite a few to 3.9 ratio.
Drive in drive out $ 1350.00, That's with motive gears.
As far as speedo correction goes i have the luxury of a flash tune box so he referred me to a speed shop down the road from them, they will correct it for a carton !!
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2008, 07:32 PM   #11
5.0 ED
5.0 ED's Avatar
Yes 3.89's and 4.11's go straight into normal diff housing, have done both before.
Old 06-12-2008, 11:14 PM   #12
Gonz
Gonz's Avatar
1950/3.23 = 603.72
cheers, your the man, once i get home ill check what ratio i currently have and go from there, i thought i had like a 2.9 or something, it feels so high, it does sit under 200RPM at 100km/h, i know that much!!
so they supply the gears and bearings? $1350.00, sounds like an ok price to me! what shop did you go to? so i recon if i just give em the diff, gears and bearings it should come well under $600 i would like to think?
cheers,
Gonz.
Old 07-12-2008, 12:29 PM   #13
CRAIGAU3220
Cat be Still !!!
Wa Diff Centre Ph 9314.2303
Old 07-12-2008, 08:04 PM   #14
Gonz
Gonz's Avatar
cheers craig, ill let you know how i go with them!!
Gonz.
Old 07-12-2008, 08:19 PM   #15
FGII-XR6
FGII-XR6's Avatar
here is a speedo calculator that makes it easy http://www.fordmods.com/forums/Speedo-Calc-d30.html
[SIGPIC][/SIGPIC]
Rides:
Old 07-12-2008, 09:26 PM   #16
CRAIGAU3220
Cat be Still !!!
Gonz.
No prob's
Old 09-12-2008, 12:19 AM   #17
Gonz
Gonz's Avatar
ahh, sweet, you guys are all over it, thankyou very much, ill post up what the out come was!!
cheers,
Gonz.
Old 09-12-2008, 11:50 AM   #18
superroo
You can't stop the signal
superroo's Avatar
The housing problem is only with the sedans 3.08 sized housing. It is smaller than the 3.23 or 3.45 housing.
Hence when people go to put 3.45 or 3.73 into their standard sedans, it doesn't fit due to the gear set being bigger than their old set.
Old 12-12-2008, 10:43 PM   #19
Gonz
Gonz's Avatar
excellent, well thats good to know, you lot are a wealth of knowledge!! all i need to do now is find the gears!
cheers,
Gonz.
Old 13-12-2008, 08:13 AM   #20
StealthAu
I had no issues, I was asked what my ratios were and when I told them they advised they had the issues with the 3.23 housings.
Who knows.....
