The Monty
i was woundering how high the tickford wings sit from the side indicators roughly ?
hope someone can get back to me a.s.a.p while the rain holds off, cheers brad` |
Just eyeball a few photos, then get some masking tape and run a line along where you want the top of the badge to sit, then you can make sure it's level before you stick it on. It doesn't have to be a specific height, as long as it's the same on both sides. I'll measure mine and get back to you if that helps, but I just stuck them where I thought they looked 'right'. This photo will give you an idea though:
#3 | |||
You can't stop the signal
They're ment to sit where mattp's are, so that an XR6/XR8 badge can fit inbetween it and the indicator.
I quite like where mine are though. Seeing as no XR badge will ever go there. ![]() Cheers
