Old 30-10-2008, 06:10 PM   #1
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Default Multi-Throttle Bodies
I'm a novice when it comes to the workings of Throttle Bodies but I've noticed that V8 Supercars run multiple Throttle Bodies (8 'cos they're V8's) I think and was wondering what, if any, benefits or pitfalls would there be with running 4 Throttle Bodies on our Eurofords?
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2008, 06:11 PM   #2
RJO89
EuroFordClub
RJO89's Avatar
Would look awesome. Trumpets popping out the bonnet!!!
Far from stock... --- SOLD :
Old 30-10-2008, 06:30 PM   #3
819_FLY
819_FLY's Avatar
I guess running independant throttle bodies means that each cylinder could be essentially tuned in regards as to how much the throttle allows air in and when, it would also mean that air in-flow would be consistant when it comes to metering air flow, where as having one throttle body at the inlet of the plenum would alow a whole heap of air to go in and the turbulence created in the plenum (usually minimal but enough) can have varied differences across the cylinders where some would be getting more air than others. Improved response would be a sign I'd assume. Quite a few of the Nissan turbo cars run multiple throttle bodies, the GTR's run 6, the GTi-R's run 4, some cars have their plenums modified to fit a second throttle body which gives improved torque down low and up highed provided its tuned properly. This is a general answer from my experience, but im sure that someone should have a more detailed answer who is specialising in this area... hahaha, i just fix cars and trucks but not too good at the designing and engineering stage, quite yet...
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2008, 07:27 PM   #4
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
It's a reasonably simple set-up to fabricate, i was looking at a set-up a bloke had built over at sigma-galant.com forums (getting ideas about the GF's car) it was for a 2.6L astron and it looked like a webber manifold with 4 throttle bodies and an injector mounted just before the end of the manifold where it meets the head.
The issue is, however, road worthiness. essentially, they're not.
Apparently, anyone feel free to correct me if I'm wrong, the intake setup needs to be in a sealed environment (hence why modern cars run an air box). For what reasons I'm not sure.
As for racing applications, as far as i know they meet CAMS requirements (i have a manual floating around somewhere if you want me to look, that and my old man is a "accredited" scruitineer)
I have also heard rumours that there's an old escort getting around somewhere with a zetec engine and a quad TB set up, If you're serious might want to track it down.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2008, 11:09 PM   #5
Mullett
Badly Focused
Mullett's Avatar
Individual throttle bodies have numerous advantages, the main one being throttle response. As mentioned before, it also balances the airflow into each cylinder (assuming the rest of the intake system is well designed) As for roadworthy, you'll need an airbox on the inlet side, which could house an individual filter for each trumpet, or be sealed and feed from a filter or filter box.
Also, this starts to get complicated. The longer the inlet runner, the more torque. The shorter the runner, the more power at higher RPM. There's some ratios around to work out the ideal runner length to suit your application, but i can't remember them at the moment. Often they'll be longer than room permits, which is why most factory manifolds are curved (to allow a long, torquey runner without taking up too much room).
Also, each runner should have a bellmouth at each end to maximise inlet velocity and swirl, and the inlet manifold ports should be matched to the head ports. The diam of the bellmouth is matched to the projected airflow and inlet volume, etc.
The reality is that for a street car, there's still lots of power and response to be had in a really good inlet setup, but for the amount of $$$ it would cost, it's not worth it.
For power, don't expect much from a straight quad-throttle swap, but your response would be fantastic. Remember that you'd most likely have to swap out the fly-by-wire throttle control for a normal cable (you could adapt the stepper motor to work, but you'd negate the gain from having the quad throttles)
If you're considering spending that kind of money...get a turbo
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2008, 01:23 AM   #6
BlackLS
yum
Cosworth's quad tb can come with a log-style manifold that fits overthe top of the trumpets which can have filtered air supplied. Main legalities I see are needing of an air filter in a box, as well as plumbing of rocker gases into the intake.
Also need to replumb vac lines. The LR comes with a cable throttle so that helps vs the LS.
Those with the LS, apparently the plastic intake manifold incorporates a butterfly that changes the length or size of the runner depending on RPM. Some US Mazda3 guys have removed the butterfly, have lost some low-down torque but gained some top end.
2005 LS Focus LX
250,000kms.
Old 31-10-2008, 09:37 AM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
According to Meridian Motorsport, they get about 180hp out of a zetec engine fitted with ITB's.(Fitted to their clubman style cars)
The problem in the Focus (LR) is that there really is insufficient space between the engine and the firewall. It could feasibly be done, but the intake is so short that useable torque for the street is crap.
I have seen it done in the UK to a Fiesta, which is a lot easier because the intake is to the front as opposed to the rear in the LR Focus (I only really know about LR Zetecs)
Pipercross make an intake box that will fit over ITB's
http://www.pipercross.net/competitio...600_airbox.asp
And they also make filters
http://www.pipercross.net/competitio...ucts_px600.asp.
I was quoted $6000 from Meridian for intake manifold, ITB's, fitting tuning, and an aftermarket ECU to control it all. Ouch.
Old 31-10-2008, 12:22 PM   #8
More revs
Great for grunt I ran 6 on my old VB rally car. Even tho it had very agressive cam timing the individual TB's also smoothed out the low end - it didn't have that lumpy cam problem a plenum does. It gave a linear curve all the way to rocker snap.. lol
Problems I see on a road car is you would have to practically junk the std ECU or run a piggyback one. Also the std injectors won't keep up neither probably will fuel pressures and flow rates so it could end up being an expensive excersise.
but yes over 180HP I heard from a UK tuner.
A cheaper thing to make a foci fast is to lighten it up. junk anything you dont need like the spare - use a can of zzishhh. junk the interior too. I recon you could save 200Kg doing this even b4 looking at aluminium bonet and plexi glass.
I remember filling a large trailer with crap out of the VB it must have been over 200Kg saved.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2008, 02:41 PM   #9
photn
AFF Post NAZI
photn's Avatar
the Quads on a focus would be great and are feasible to do at a cheap price, st170 bottom inlet, and a set of gsxr tb's and it can be done. BUT you will require aftermarket management, there will be prettty much no down low torque and your fuel costs will sky rocket. the 180hp from the zetec engine in the clubman cars is only attainable without some of its accessories. you dont really need to run a cover over the TB's but it would be advisable.
In short for road use eddie its not worth it unless you have a 3k stall and shares in al major fuel companies.
if you want ur car quicker then a bluefin, tb, exhaust and what not would be advisable. but it would have a small possibly a little more impact on your fuel consumpstion.
my 2c from my research on my focus.
Old 31-10-2008, 08:25 PM   #10
20focus05
I wanna XR5
20focus05's Avatar
Check out Burton for 4Cyl go fast bits ie Cosworth
www.burtonpower.com from the UK
A mate from work gave me a catalogue
Some top quad throttle body stuff they have
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2008, 12:12 AM   #11
Mullett
Badly Focused
Mullett's Avatar
180hp is absolutely do-able, but remember that the duratec has over 140hp standard...so that's a 40hp gain for what I guess would be cams, extractors, intake, exhaust, aftermarket ECU...and all the associated bits. I'd guess 8k if you were to pay someone to do it...much cheaper to put a turbo on it! I'd say that it's totally worth it for a 500kg kit car, but not for a 1200kg roadcar, where the extra weight of the turbo is marginal, and the midrange torque would make a huge difference to the driveability (in a clubman, you don't care if you're constantly revving the nuts off it, or how much fuel it uses, for a daily driver...I know what I'd rather
All of the above said, there's nothing quite like a really hot NA 4cyl
oh...and for an LS onwards forcus I think you'd have a very hard time putting a totally aftermarket ECU on it, the dash and ECU talk to each other...but you can tune the stock ECU
-RM.
