Old 28-10-2008, 10:35 PM   #1
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Default Changing ECU, Smartshield??
G'day Guys,
Just swapped the ECU on my mates AU 220 to try and eliminate that from being the cause of a few idle issues etc.
The car is a 2001 AUII XR8 220kw and 5spd manual. The ECU catch code is 12QB.
The new ECU we got is also from a 2001 AUII XR8 220kw, 5spd manual and also the catch code is 12QB.
Now this afternoon we done the ECU swap and the car is now not starting and i believe it must be the Smartshield light flashing on the dash (Hand with a car inside it).
Can anybody confirm that it is the Smartshield light and shed some light on how this problem is overcome?
Im guessing there is a certain procedure to remove the light and enable the car to start.
Any help/info is greatly appreciated.
Cheers,
Jeff
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2008, 11:40 PM   #2
philstoj
philstoj's Avatar
Mate your going to have to get yourself a very good scan tool like the snap on one, and you are going to have to link the new ecu to the BEM, only way your going to get the other ECU to work in there.
Too many codes et, processes etc, bugger of a job.
Ford do this, but going by a recent experience they are hopeless and lazy.
Old 28-10-2008, 11:43 PM   #3
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Shite, that doesnt sound good.
What do Ford charge for this sort of thing?
Old mate isnt going to be impressed.
STREETBUILT RACING
Old 28-10-2008, 11:47 PM   #4
philstoj
philstoj's Avatar
The prices vary,dont they charge $100phr these days?
But they wont fit a second hand ECU to a car that they havent supplied, so they expect a car to be a runner before they will do anything.. best to go to a good mechanic, they will have the tools and do a better job.
Old 29-10-2008, 08:52 AM   #5
The Mighty Red
The Mighty Red's Avatar
Damn sounds expensive, sorry I can't add anything to help....goodluck with it.
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2008, 10:43 AM   #6
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
What about if i get the BEM from the car the ECU came from??
STREETBUILT RACING
Old 29-10-2008, 11:03 AM   #7
T-Pak Addict
Jim
T-Pak Addict's Avatar
you will need the ECU, BEM, ignition and keys (they are coded on smartshield) that match the setup. Then it should fire right up.
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2008, 11:17 AM   #8
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Hmm, interesting, cheers for that mate, will see what i can do.
Im guessing he will have to change the door locks aswell?
STREETBUILT RACING
Old 29-10-2008, 01:30 PM   #9
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
If you want them to match the ignition key you will
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2013, 12:42 AM   #10
sirthing
Default Re: Changing ECU, Smartshield??
If you put key barrel ecu and bem in yourself 20min job if you just pull steering column out of wreckers (make sure you get keys and buttons for it)
Take it to ford they will charge you $93 to code it all up an $109 labor they charge this coz it takes 61 minutes to code so they tryed to tell me so get them to do something small will they wait only know as I just vct change into au2 fairmont finished last week an gonna go back in shed soon for turbo soon
sirthing is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2013, 05:59 PM   #11
ROOSTA
DFDFDF
ROOSTA's Avatar
Jeff.. Get a QuarterHorse and with it you can disable the security side of thinhs.. Plus drop a tune in.. ;-)
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2013, 07:26 PM   #12
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Umm, anyone notice this thread be 5 years old
2002 AUIII XR8 n/a: 13.65@101.8mph.
With Raptor Assist:..12.73@111.5mph.
With ET Streets:......12.44@110.7mph, a one time fluke.........12.54@110mph back to back.
With 3.9 Gears:.......12.40@112.5mph, still trying!
Tune by XFT
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2013, 08:03 PM   #13
ROOSTA
DFDFDF
ROOSTA's Avatar
Oh.. HahahhahahHahahaha..
Old 13-08-2013, 11:20 AM   #14
BOTTLEDUP
BOTTLEDUP's Avatar
Yes I think Jeff has this sort of thing figured out by now...
T1 TE50 P01
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2016, 02:57 PM   #15
Rfordsfun
Digging up my code got grabbed by a code grabber, and house kepys stolen.
My question is, if I swap ignition barrel, and keys. will I need the ecu bem or just the door lock ?
Bloody scum bags and their mail order theft devices, its and AU3 thanks in advance
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2016, 03:58 PM   #16
KRL-94
If you change 1 part of the computer set, you need to change the rest or get it all linked again.
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time.
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
http://www.fordforums.com.au/showthread.php?t=11447916
KRL-94 is offline   Reply With Quote Multi-Quote with this Post
