16-08-2008, 08:19 PM | #1 | ||
not here much anymore
Guys
before i take a sledgehammer to my dash, was just wondering if anyone has ever had a problem with a real squeaky rattle right up under the windscreen. There is the panel there that has the vents in it for the window demister and it is underneath that, I am thinking it is possibly a clip or something that holds the heater pipes etc on there? Any ideas?
2024 F150 XLT
16-08-2008, 08:22 PM | #2 | ||
nah, no ideas on that, but my glove box opener rattles, grrr
i would think it would be clipped in, but not sure if you could get to it without removing the whole dash... |
16-08-2008, 08:28 PM | #3 | |||
2024 F150 XLT
16-08-2008, 10:32 PM | #4 | ||
mine squeaks between the two panels-like they rub on each other. does my head in too!- just turn stereo up, one day i will fix it.
17-08-2008, 12:54 AM | #5 | |||
Smile
Describe the sound better.Is it metalic? Is it like a loose panel? Post it so we can assist you better.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
17-08-2008, 01:00 AM | #6 | |||
U shouldnt hear it over your big loud exhurst |
17-08-2008, 06:36 AM | #7 | |||
Blown 5L coming
i have an anoying squeak in the center of the dash where the plastic face of the a/c controls and stereo surround rubs against the vinal of the dash....just turn the music up a bit louder and i cannt hear it.....one day i may do something about it.....but not overly concerned.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
17-08-2008, 07:41 AM | #8 | |||
17-08-2008, 08:09 AM | #9 | ||
My wagon has a squeak right up near the windscreen too,if you've had a bit of a push and pull around the area,try the age old remedy of a full can of silicon spray it works wonders on sqeaks,thats all FORD use for any thing that wont fix it self
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
17-08-2008, 08:26 AM | #10 | ||
Have to join the club here.
Have been searchin for a squeak for weeks. Noow that I've lowered and its so much stiffer it's drivin me nuts. : |
17-08-2008, 09:03 AM | #11 | ||
Narooma blue XR8 ute
I have a sledgehammer you can borrow
17-08-2008, 09:36 AM | #12 | |||
I had one in a similar area, and found that it went away with an air freshner mounted on one of the center air vents. |
17-08-2008, 11:03 AM | #13 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
17-08-2008, 11:23 AM | #14 | ||
I miss my wheelbarrow
I have the same.
Its funny, you hardly hear Taxi's squeaking in that area - therefore as somebody above mentioned, it has to be the effects of a lowered, stiffer (and hard driven) car. Daniel |
17-08-2008, 12:05 PM | #15 | ||
mine does to, i found mine to be the dash panel just touches the windscreen and makes it creak and does it when going down gutters to, i think the car is twisting when going over bumps crooked
17-08-2008, 02:42 PM | #16 | |||
17-08-2008, 10:10 PM | #17 | ||
Smile
The cover youre talking about is held by philips head screws. When you get a chance Undo the screws and remove the panel. Then check the tightness of the retaining bolts for the dashboard to the firewall. Forget the sledgehammer ..find the problem.
17-08-2008, 11:01 PM | #18 | |||
_Oo===oO_
Or you can harden up. : Personally, I don't bother chasing the squeaks and rattles I might make things worse.
18-08-2008, 06:21 AM | #19 | ||
Fantastic Plastic
I had an annoying rattle that sounded like it was coming from my dash, I couldn't find it for the life of me. About 6 months later i found the rattle , it was coming from the rear vision mirror vibrating !!!, changed it and all ok now. It realy sounded like it was coming from the dash area at the time, it was driving me nuts.
18-08-2008, 07:55 AM | #20 | ||
Bah, ive pulled it out about 5 times already. Im going to try the silicone spray option today.
2024 F150 XLT
18-08-2008, 08:44 AM | #21 | |||
18-08-2008, 11:18 AM | #22 | ||
Monsoon SIII XR8 220
When I first got my xr8, I had this noise and I managed to track it down with much perseverance! It is not actually coming from inside the car but on the outside. If you look at the plastic cowling that touches the windscreen right by the windscreen wiper arms and give it a push you will hear the noise. I used silicone grease on the back of the plastic which lasts for a while. Hope this helps.
Cheers, Simon ps. I have a great fix for the rattly centre air vents if anyone is interested. |
18-08-2008, 12:03 PM | #23 | |||
RIP...
. Oval Everywhere... |
18-08-2008, 01:12 PM | #24 | |||
I've got exactly the same squeak in mine as well... It also looks to me like that trim/panel right at the front of the dash pad is distorted... Maybe from the heat of our WA sunshine. :( I want to fix the noise because squeaks/rattles drive me nuts. If I want to hear a car falling apart I drive my VN. |
18-08-2008, 06:47 PM | #25 | ||
Thanks to Stav for correctly picking it - loose bolt where the dash bolts to the front end of the car. Put a bigger washer on it and tightened it right up - squeak gone for now but the real test will come going to work tomorrow.
2024 F150 XLT
18-08-2008, 07:07 PM | #26 | ||
Smile
No worries mate. If it comes loose and squeaks loctite the bolt. Glad I could help
18-08-2008, 08:19 PM | #27 | ||
have the same problem with my car, but it's not low or stiff or hard driven...
i have found a quick fix for when it really annoys me, the handy moist towelette (spelling?) from KFC. just jam said moist wipe (still in the packet) between the 2 panels and walla no noise (for a little while) -tim who will spend some spare time fixing problem properly now that i know how.. |
18-08-2008, 08:38 PM | #28 | ||||
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
