Old 29-06-2008, 10:22 PM   #1
paddy351
Ford Nut
paddy351's Avatar
Default Running with pipes off
Hi guys just wondering about running at heathcote with the pipes off my xw. I have herd that you gain power but you could loose torque and how does it alter your tunning. Thanks -Pat
Clevo + toploader = :
paddy351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2008, 08:25 AM   #2
jcxr
Tribal Elder
jcxr's Avatar
Sometimes its handy to be able to hear your engine, to get shifts right, so open pipes are a bonus in that way.
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 07:13 PM   #3
forcd6
forcd6's Avatar
Probably a good thing that you throw it up on the dyno with the pipes off to make sure that your not leaning out before you race it a Heathcote. Might save you a motor.
forcd6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 07:20 PM   #4
blueprintxr
born into ford herritage
blueprintxr's Avatar
id be happy to be there to hear it reguardless :p
blueprintxr is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2008, 11:28 PM   #5
capriv8
I gained three tenths in the Mustang with the pipes off, 10.90 down to 10.60, I didnt make any other changes also the sound is awesome at 7000 rpm running through the finish line.
capriv8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2008, 01:18 AM   #6
paddy351
Ford Nut
paddy351's Avatar
Thanks for that fella's
Old 03-07-2008, 05:05 PM   #7
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Forget dyno's,the way I would do it is have a couple of runs pipes on first,then drop the pipes and see what it does,I know of more than a few instances of street cars going slower pipes off..
It really amuses me when I see guys with 400hp engines rock up and immediately drop pipes,all the while never knowing if they gained anything,except a maybe slower 11 or 12 second car that now sounds like a top fueller..
My last car went just as good pipes on..and sounded better IMO..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2008, 09:39 PM   #8
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
My xr8 goes harder with the pipes up , 2 tenths quicker
ED xr8, STD 5.0l short block
AFR165 alloy heads
11.92 @ 113.5mph N/A
10.98 @ 122.2mph 100hp nos
377 RWHP @ 5900rpm N/A
No longer bottle fed, now with boost
9.67 @ 144 mph on 22psi
xr8 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2008, 12:44 AM   #9
paddy351
Ford Nut
paddy351's Avatar
thanks nugget and xr8 5.0 i will try both .
Old 04-07-2008, 08:56 AM   #10
Barry_v
rocknrolla
Barry_v's Avatar
with the helmet on and a open pipes car next to you its impossible to hear your own engine if you leave the exhaust on.
1979 P6 LTD 383c
1970 ZC Fairlane 500 351w
1964 XM Falcon Deluxe 200ci
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2008, 01:19 PM   #11
nugget378
Weezland
nugget378's Avatar
Its something you do get used to,I listen to the tone of the engine rather than the exhaust,but mostly keep an eye on the tach.
Old 06-07-2008, 09:57 PM   #12
ClevoCapri
ClevoCapri's Avatar
I gained from dropping the pipes. From a 10.9-10.5@127mph. I do have a rather crap exhaust though. It goes from 3.5inch collector to twin 2 1/4 into a single 2.5inch.
So i guess if you have a decent exhaust you shouldnt expect too much improvement.
ClevoCapri is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2008, 11:46 PM   #13
paddy351
Ford Nut
paddy351's Avatar
I run 4-1's ,3inch duel into 3inch single pipe.
Old 07-07-2008, 08:13 AM   #14
gregaust
That should be plenty of exhaust. Be surprised if that makes a difference.
2-1/4" pipes on a 10 sec car,not surprised it went faster..
Old 07-07-2008, 09:52 AM   #15
ToddZC
Thunderbolt driver
ToddZC's Avatar
My old silver barge ran the same with pipes on or off, but then again it had a nice exhaust. Dual 3 1/2" from the collectors to through the mufflers. It made it hard to hear the engine at idle when the car next to you ran an open exhaust, but once the engine was revving I could hear it okay.
Thunderbolt Racing Team
You can't spell FEar with out an FE.
ToddZC is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2008, 09:21 AM   #16
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
That's because the barge was now way out in front!
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2008, 09:39 AM   #17
TruBlu351
TruBlu351's Avatar
May trend towards the leaner side with pipes off, so you may need to fit slightly bigger jets..........looking for max mph.
Old 13-07-2008, 11:42 AM   #18
xdclevo
The Fun Mobile
xdclevo's Avatar
I gained 3 tenths when i dropped the twin 3" dumped at the diff, and ran extractors only. Looking at the plugs, it didn't seem to change the tune any noticeable amount.
I did have the 750 Demon modified so that would contribute a bit possibly too, so not sure what exact gains made.
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
