Old 17-06-2008, 10:43 PM   #1
Stav
Smile
Stav's Avatar
Default ba flyby wire to au?
Can it be done? What voltages control the ba throttle body? I am up to noooo gooood
Old 17-06-2008, 10:44 PM   #2
bodes-sh
ba's 5-0v, 5 being closed.
Old 17-06-2008, 10:44 PM   #3
private9
www.TUFFCARPARTS.com
private9's Avatar
What performance advantage would it offer?
Old 17-06-2008, 10:48 PM   #4
bodes-sh
probably doable, would you keep the au t/b or use the ba one tho? only issue i can see is idle control as the ba is all ecu controlled, as for what for, i'd say w*nk factor, just to prove you can lol
Old 17-06-2008, 10:48 PM   #5
Stav
Smile
Stav's Avatar
Private...it is not the throttle body I am intersted in but the mechanism which drives the throttle body plate.I cant say too much this early in this idea I wish to develop as I dont want to end up with egg on my face.Lets just say it has never been done before!! Depending on costs it may never happen but please bear with me.If it works I am going to patent my idea!! If it works were gonna break some hearts!!
Old 17-06-2008, 11:00 PM   #6
Stav
Smile
Stav's Avatar
0-5 volts is easy done!!Thanks bodesh!! :
Old 17-06-2008, 11:10 PM   #7
bodes-sh
it's pretty close to that anyway, but just play around slightly with it till you get it right, definitely 5-0 tho, not the other way around
Old 17-06-2008, 11:12 PM   #8
private9
private9's Avatar
Got ya! BBM related no doubt!
Old 17-06-2008, 11:21 PM   #9
Ruger
Bseries Moderator
Ruger's Avatar
Hey Stav, i did alot of fiddling with these. Few things to consider:
Keep in mind its an electric motor and electric motors run off a sine wave and need special speed controllers to control them. This goes for nearly all electric motors ranging from remote control cars to big 3 phase water pumps
When hooking up the secondary throttle body as electric i used the jaycar motor/servo controller kit and even then it would turn on and snap the throttle open when it needed to be. Hooking up straight power from the battery (even regulated) resulted in nothing since it needs to be a sine wave (500hz iirc) i had all the data sheets for the electricals of these TB's but have since lost them all.
Its not all that simple i found but give it a shot.
If you need a TB to play with let me know i may have a few parts still laying around.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 11:38 PM   #10
Abacus
Life's a Gas
Abacus's Avatar
I find the flybywire a PITA. I much prefer the feel of the AU throttle.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 11:50 PM   #11
Stav
Smile
Stav's Avatar
Can I run 2 throttle cables?
Old 17-06-2008, 11:55 PM   #12
bodes-sh
imp, i haven't found the ba throttle to be too much different to the au one. the alloytec commodore ones are set up like s*it tho, it's all or nothing, in vz and ve...there's no smooth acceleration in them, ba's i have found are still fairly linear
Old 18-06-2008, 12:32 AM   #13
Abacus
Life's a Gas
Abacus's Avatar
I find quite the reverse with the BF - you kind of have to depress the throttle about about 1/2 of the way down before you get any significant response. You're pushing against the spring for the first bit, but nothing is happening under the bonnet.
Old 18-06-2008, 01:08 PM   #14
EvilChief
Boost Addict
there are three sensors on teh foot pedal of the BAs
1) Ascending potentiometer
2) Descinding Potentiometer
3) On/Off Switch
the ECU calculates the throttle opening from the values of the ascending and descinding potentiometers, the on/off switch is used for idle switching and traction control.
the ecu not only uses these inputs for throttle control but also but also traction control and torque limiting control (gearbox safer).
so now u gott find a way to use these sensor inputs to create a signal to the TB motor (unsure if its a frequency based signal or a voltage based one)
food for thought ...
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 18-06-2008, 07:05 PM   #15
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Abacus is on the money. I HATE FLYBYWIRE. I want instant. i say go it should go.
Its not only fords either. The commodores are worse. Late last year my work car got 'upgraded' (pfft) from an awesome VYII wagon to a VZ wagon. What a heap of puss the VZ is - and the electronic throttle is the culprit.
I will say, i can't notice the electronic throttle on the VE's though. They are damn fine cars, with one or two exceptions.
Old 18-06-2008, 08:14 PM   #16
EvilChief
Boost Addict
YUP called torque limiter or torque control. can easily be reduced through flashing :
N12 Pulsar - sold
Old 19-06-2008, 09:37 AM   #17
Mr Hardware
good. cos it ruins your driving experience entirely.
