Old 08-06-2008, 07:43 PM   #1
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Default my au motor imploded
well it didnt quite implode, but i was driving along yesterday down wellington road near clayton uni, and the car started hesitating badly, so i dropped it back to neutral, and it stalled. i pulled over, switched to petrol to see whether or not there was somethng wrong with the gas, but there wasn't. it still didn't fire, just cranked and compression locked.
the engine is in an ed fairmont, and uses a dizzy instead of the coilpack.
so anyway, today we went back and tried to figure out what had happened. it wasn't the coil because there was spark, and it wasn't fuel cos there was plenty coming through. i took the dizzy out, and had a look down into the engine, and saw that it was pretty mangled.
we figured out that whatever the shaft is that the dizzy connects to inside the block, has been stripped or bent, or something, causing the starting problems.
anyone got any more info for me as to whats inside that bit, or a diagram or something?
thanks guys
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2008, 07:56 PM   #2
EL__Monty
you have stripped you auxillary shaft. So your oil pump must have siezed which stops the auxillary shaft from turning thus stripping all the teeth.
Big job to repair$$$$, probably drop the sump and have a better look, broken timing chain guide can cause this or bits of foreign metal filings in the sump oil.
EL__Monty is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2008, 11:21 AM   #3
Christiaan
Christiaan's Avatar
wow, this sucks.
i just got it towed to the workshop, dad's gunna take the engine out and check everything out.
it wasn't low on oil, so i'll check the timing guide and stuff.
i wish this sorta stuff didn't happen to me :(
Old 11-06-2008, 07:56 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
Bad luck mate.
Since you're gonna pull the engine anyway, it would probably be cheaper and safer, to grab another low km AU long motor and swap that in.
Just get it without accessories to save some bucks. They seem to be getting pretty cheap these days, and I've seen them as low as $300 with apparently good kms.
Old 12-06-2008, 05:03 PM   #5
SeXC
Pushrodosaurus Rex
SeXC's Avatar
ive also seen v8 windsors from aus sell for 500 complete......
better than a 6 pot
SeXC is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2008, 09:18 PM   #6
private9
private9's Avatar
Originally Posted by SeXC
better than a 6 pot
Do you really wanna start that argument?!
Please do, it's always soooo entertaining
Old 12-06-2008, 09:20 PM   #7
RG
Back to Le Frenchy
RG's Avatar
Not our problem you lack something up front
Old 12-06-2008, 09:31 PM   #8
private9
private9's Avatar
Yay, our smiley's dance in unison^^^^!
I admit it, I am secretly a wheezer V8 lover - there's something just right with their combination of a perfect sound and lack of power!!!
Old 12-06-2008, 10:04 PM   #9
RG
Back to Le Frenchy
RG's Avatar
Perfect sound + lack of power + lots of $$$ = lots of power!
Problem solved! :
Old 12-06-2008, 10:12 PM   #10
sly
Sly like a G6
sly's Avatar
Perfect sound? A wheezer sounds nothing like a 3.8 litre MkII Jag! :
Sleeper, anyone?
Old 13-06-2008, 05:10 PM   #11
SeXC
Pushrodosaurus Rex
SeXC's Avatar
hahaha look at the mess i created!
Old 17-06-2008, 12:07 PM   #12
Christiaan
Christiaan's Avatar
Ok guys,
got the car back from dad, he replaced the timing chain, aux gear, dizzy shaft, various other things, and chucked it back in. running very smooth now and looking good. with the tow (90km's) it cost just under $500 for everything, so i'm happy.
Old 17-06-2008, 12:21 PM   #13
Black XR
Narooma blue XR8 ute
Black XR's Avatar
good to see you got it all sorted and without spending to much
Black XR is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 09:20 PM   #14
private9
private9's Avatar
Originally Posted by shuresm58
Ok guys,
Good work mate!
Old 18-06-2008, 09:40 PM   #15
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
Hey
Thats not nice, Damn i hate biting my tongue. :
Good to see you got it all sorted out shuresm58 and at good deal.
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
