Old 03-06-2008, 11:03 PM   #1
Mont5.0
Mont5.0's Avatar
Default boot leak
Anyone else got the problem of water getting trapped in behind the boot lid carpet? I experienced this for the first time today, and was quite shocked at the amount of water that came gushing in through the boot latch(seems to sit in between the two layers of sheet metal which make up your boot lid). anyone know of a easy fix for this problem? was thinking of drilling 2 small holes either side of the latch so it naturally runs out whilst the boot is closed. I would prefer not having to drill holes if able to do other ways??
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 11:13 PM   #2
mattp
mattp's Avatar
Do you have a spoiler? I know this can be a cause of leaking boots, improper or poor seal around the spoiler bolt holes. If not, where is it getting in?
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 11:17 PM   #3
Mont5.0
Mont5.0's Avatar
yep got the series 2 fairmont low spoiler. it seems like it is getting up between the carpet and the bootlid (rear window edge of boot lid) how?- i dont know, was thinking maybe forced up whilst traveling. (is a bit hard to explain)
Old 03-06-2008, 11:34 PM   #4
Mont5.0
Mont5.0's Avatar
http://www.fordforums.com.au/showthr...8&page=2&pp=25
just found this thread from B series, might give their ideas a try.
Old 04-06-2008, 09:22 AM   #5
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
I have the same problem. Havent tracked down the leak yet. The water is actually sitting inside the bottom of the boot lid as you said. When you tip it up to open it, it runs out and sits in your boot lid carpet & runs everywhere. I have drilled some small holes in the bottom of the boot lid on the outside of where it sits on the boot rubber seal so that it can drain away whenever any gets in there. I will one day track it down, but for now this was the quickest & easiest fix. Mine has the wing aswell, so may be coming from that. A mate has a dunnydoor with the same prob, and the holes fixed it (By fixed i mean did it the easy way, found a fix for the problem without fixing the problem). When i have time will get someone to shut me in the boot and hose it so i can see where its coming from.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2008, 09:24 AM   #6
autickfordfairmont
Tickford Equiped
To add to it, mine was actually that bad that I removed my spare wheel the other day to find it half submerged in water, so i put 2 small holes in the bottom of the well to let that drain to if ever it happens again. The holes are only big enough to let water drain, without being big enough to let water in when its raining (or getting the odd underbody wash) and getting splashed up and around there.
Hope this helps.
Old 04-06-2008, 09:37 AM   #7
Mont5.0
Mont5.0's Avatar
Cheers. Yep will be doing the same. As for the spare wheel well- mine is missing that large grommet that usually resides in there, so mine flows out quite easily.
