Old 15-05-2008, 09:05 PM   #1
ayeyew
Teh Baest
ayeyew's Avatar
Default Running power cables for sound system??
My mate and I can't really find anywhere to run power cables through the firewall?
He said it looked like the power cable actually ran underneath the car, but he didn't particularly want to do this..
Is there any other way to run the wiring?
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2008, 09:10 PM   #2
ayeyew
Teh Baest
ayeyew's Avatar
Search is a good tool isn't it...
LoL
Currently:
Old 15-05-2008, 09:12 PM   #3
StealthAu
Is it an auto? If so use the hole for the clutch cable
Old 15-05-2008, 09:15 PM   #4
ayeyew
Teh Baest
ayeyew's Avatar
Yeppers
I think that's what i'll be doing
Where exactly is it?
Currently:
Old 15-05-2008, 09:18 PM   #5
ayeyew
Teh Baest
ayeyew's Avatar
Actually just found some pics from someone elses car on this forum
Hopefully the 4ga will fit thru it
Currently:
Old 15-05-2008, 09:21 PM   #6
StealthAu
You'll find it, in the engine bay to the right and down from the brake booster, kind of a tube sticking out, and to the left of the brake pedal in the footwell. Once you've run it all and have everything setup (so you know lengths are right) rap a cloth around where the cable exits the metal tube in the foot well, and fill it up with sikaflex from the engine bay to prevent the sheath rubbing back.
Old 15-05-2008, 09:23 PM   #7
ayeyew
Teh Baest
ayeyew's Avatar
Cheers mate
I'm sure this info will help heaps on the weekend if it gets done
Will def post pics of the completed install
Already have my deck + front splits in, no amp no nothing and it already gets damn loud..
Looking forward to the monster subs and HUGE amps
I should feel right at home in a maccas carpark at around 1am
Currently:
Old 16-05-2008, 12:13 PM   #8
brad`
The Monty
brad`'s Avatar
4guage should only 8 guage i heard is a really tight fit
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 12:18 PM   #9
75van
Van Mad
75van's Avatar
Other way around? 4GA is bigger than 8GA, so if 8's a tight fit 4 isn't going anywhere near it!
The new wheels: 1975 Ford Escort panelvan. Build blog here.
75van is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 12:22 PM   #10
InfernoSR
Sales Representative
InfernoSR's Avatar
I used the hole for the bonnet release cable... and i used 4ga...
Old 16-05-2008, 11:19 PM   #11
brad`
The Monty
brad`'s Avatar
lol my bad, thats what i ment 4gauge.. yeah but he is going to use the clutch cable hole. haha
Old 17-05-2008, 11:44 AM   #12
ayeyew
Teh Baest
ayeyew's Avatar
Looks like an aftermarket alarm or something is using the clutch cable hole :(
Currently:
Old 17-05-2008, 11:50 AM   #13
InfernoSR
InfernoSR's Avatar
Bugger... looks like you might have to go with what we discussed via PM... :
Old 17-05-2008, 02:58 PM   #14
ayeyew
Teh Baest
ayeyew's Avatar
LoL
I might have to
Although i tried stuffing the power cable through the same hole as the aftermarket alarm cable and it seems like it MAY go through JUST
Currently:
Old 17-05-2008, 02:58 PM   #15
Serge
Serge's Avatar
you could just drill a hole in the firewall, I did mine on the left hand side on the bottom right it came out just around the foot rest pedal, il throw a pic up if i can find it.
Serge is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 09:47 PM   #16
Mechan1k
Mechan1k's Avatar
I am running my 4ga power through the clutch cable hole with grommet.
Old 17-05-2008, 09:59 PM   #17
brad`
The Monty
brad`'s Avatar
wel..im be quiet then
Old 19-05-2008, 10:33 PM   #18
ayeyew
Teh Baest
ayeyew's Avatar
Ended up running it through the big grommet just above the bonnet release cable.
Took a while to get it through, but it's there now
Now the next fun part...
Getting the speaker cable through to the door...
Currently:
Old 20-05-2008, 02:10 PM   #19
bloggs24
cant you just use the cars stock wiring? although when i get new speakers i think id rather run fresh wires.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2008, 02:21 PM   #20
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
i ran 4ga throught the clutch cable hole and i also used the cars stock wiring for the speakers (fronts only) so didnt have to muck around putting a wire through the door.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2008, 03:32 PM   #21
ayeyew
Teh Baest
ayeyew's Avatar
At the moment i am running the fronts off the stock wiring, but im putting in a T400-4 amp in the not too distant future. Would rather have some 10ga wire for that
I bloody did it the other day, taped the wire to a coathanger, got it through the door and into the firewall, then using some pliers to get it through the firewall.. Finally got the coathanger through and was thinking YESSSSSS!! Then noticed the wiring was no longer attached to the coathanger... BASTARD
Currently:
Old 20-05-2008, 03:43 PM   #22
InfernoSR
InfernoSR's Avatar
Why did you go from the door through the firewall? you mean to inside the kick panels?
Old 20-05-2008, 06:02 PM   #23
ayeyew
Teh Baest
ayeyew's Avatar
LoL
kick panels
my bad
lmfao
Currently:
Old 20-05-2008, 06:48 PM   #24
InfernoSR
InfernoSR's Avatar
LoL
kick panels
my bad
lmfao
Ah... now that makes more sense
Old 20-05-2008, 06:56 PM   #25
ayeyew
Teh Baest
ayeyew's Avatar
Was just seeing if you were paying attention :voldar02:
Currently:
