Smile
Guys. I ran back to back 14.3's in summer 25 degree tepms and 40 degree track temps.
What improvement in et is typical from 25 degrees to say 15 degrees?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#2 | |||
It's why you see drag racers using specialist air density gauges to monitor air.... they measure in feet above and below sea level. Good air like at the Winternationals at Willowbank could see 400 feet below sea level but it is also freezing cold. Sorry I can't give a definitive answer but it depends on the car, tyres, track condition (dew, number of cars run). It may run a tenth or two but who knows. |
Smile
My own experience has been from 15.2 in 30 degrees to 14.7 in 18 degrees.That is also with intake piping change and bigger cat. So I supppose only time will tell. I have not modified anything on the car since my summer run. It will be an interesting little experiment.
#4 | |||
Location: Working, chasing after my daughter and working
Relative altitude is where you will see how good the air is, Ive found for every 1000ft drop in RA you gain about 1.5 tenths if everything else is the same (ie: 60ft, setup etc).
Here's a RA calculator, take into account WSID height above sea level is 230ft. Have a play and you will see what makes the most difference.RA calculator Also take into account any air under 1000ft RA is becoming good air, the best Ive see myself at WSID is 187ft, as someone else said sometimes it can be below sea level reading, which is killer air. Last edited by Quadcams; 05-05-2008 at 04:09 PM. |
Smile
So what numbers do we plug in? Timeslip show humidity,track temp,air temp and abs barometer. Ive put in 230 feet 10 degrees ..what is altimeter?
edit..altimeter is barometric pressure.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() Last edited by Stav; 05-05-2008 at 05:48 PM. |
Smile
230 feet,77 degrees,29 altimeter,relative humidity 88%
=density altitude 1732 feet absolute pressure 29.732 inches hg relative density 95.% This was from my 14.301. run .Is this good air? With all else being equal to make a good impact to ra I need to run in 14 degrees or better.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() Last edited by Stav; 05-05-2008 at 06:07 PM. |
#8 | |||
Smile
Thanks for the info man..
