Old 29-03-2008, 05:42 PM   #1
ayeyew
Teh Baest
ayeyew's Avatar
Default How to change plugs & leads
I'd like to have a go at changing these over on my series 1 as i bought some today.
Looked in the technical resources section, couldn't find a how to on it, but is it relatively simple or should i get one of my mechanically inclined mates to do it?
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2008, 06:00 PM   #2
EvilChief
Boost Addict
not mechanically challenging, just physically, hope u got a flexible arm
plugs is straight forward, just remember to use a little bit grphite grease on plug thread and ensure that the crush washer is properly cruched when plugs are to be reinstalled
as for leads, dont mix up the order:
front pair: 1 & 6
middle pair: 2 & 5
rear pair: 3 & 4
removed air box and intalke snorkel and ensure engine is dead cold, other wise u WILL burn urself on heater pipe
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 29-03-2008, 06:05 PM   #3
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I find swearing helps when putting the coil end on. I like to do it from underneath.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2008, 06:10 PM   #4
ayeyew
Teh Baest
ayeyew's Avatar
Yeah i got some dielectric grease from supercheap auto, is that the same stuff ur talkin about?
OOOOFT.
/confidence plummets
Currently:
Old 29-03-2008, 06:24 PM   #5
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
OOOOFT.
No - you can do it, its just fiddly and if you have big hands/fingers its just a fraction harder.
You will get it done.
Just a few.
Old 30-03-2008, 10:04 AM   #6
fordman_01
DUB
damn if only i new bout this earlier lol. last week i forked out almost 200 buks to get new NGK leads put in from my mech......:(
fordman_01 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 10:19 AM   #7
Chamelion
Your mech ripped you off something awefull. It took a mate and I about 15 minutes first go to get it done. I could have done it myself, but it would have taken 10 minutes more.. Through either moving the airbox out of the way or passing each lead down one at a time, then hopping under each time to connect it.
Absolute peice of cake, even for a newbie.
Matt.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 10:20 AM   #8
Chamelion
OOOOFT.
Even a small ammount of engine oil does the trick.
Old 30-03-2008, 11:31 AM   #9
schuldiner
best bet is to take them off one at a time and replace them individually, that way you cant mess up the firing order. as stated just remove airbox and pipework up to the throttle body, give your throttle body and maybe your Idle control a clean out while it's apart and it takes a bit of fiddling to do from the top but you can get it no worries, wont take too long.
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2008, 03:16 PM   #10
ayeyew
Teh Baest
ayeyew's Avatar
Cheers for advice guys.
Just got home from a 30 min drive, gonna wait an hour or so for it all to cool down and then give it a go.
I had better not stuff this up! LoL
Currently:
Old 30-03-2008, 10:29 PM   #11
Flyn
AU 1
OK for the plug leads....but what about the coil pack. Is it possible to replace this from the top?
Flyn is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2008, 10:12 AM   #12
bodes-sh
nope, you can't get it out as there isn't enough room between the inlet manifold ans the block, tried it before....
Old 31-03-2008, 10:22 AM   #13
amisupposed2b
I must admit, the changing the leads has lead me to get really irritated with where they put the coil pack....
amisupposed2b is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2008, 10:16 PM   #14
InfernoSR
Sales Representative
InfernoSR's Avatar
I found the AU easier than my XG ute... which is easier than my parents DA1 LTD...
I ended up having leads that were numbered anyway, which made things alot easier... :P
Old 31-03-2008, 11:10 PM   #15
private9
www.TUFFCARPARTS.com
private9's Avatar
If the EF coilpack location is the same as AU (which I think it is), I remember it being a bastard of a job! Didn't take long, maybe 20 minutes as a first timer, but boy was it painful!!
Old 01-04-2008, 08:43 PM   #16
ayeyew
Teh Baest
ayeyew's Avatar
Even with the numbered leads i still managed to screw it up! Even changing one lead at a time! I am perplexed how i managed to not get it right first go.
Definately not a hard thing to do, but as you guys said, physically challenging!
Took me about 40 minutes to complete it, that includes taking the airbox and pipework off twice when i realised i had stuffed up the firing order, lol.
Once again, cheers for all your help guys
Currently:
Old 01-04-2008, 09:17 PM   #17
schuldiner
when you screw it up and it's misfiring (i got distracted and didn't plug one lead into the dizzy) it feels like your car is being hit with a sledgehammer hey? horrible feeling:P
see my ute here
AU parts for sale
Old 01-04-2008, 10:17 PM   #18
ayeyew
Teh Baest
ayeyew's Avatar
Oh my God, doesn't it ever!
I felt sick after that and when i fixed it all up and plugged all the leads in properly, i didn't want to turn my key, lmfao. It seriously took me like 2 or 3 mins to build up the courage to turn it
Currently:
