Old 17-03-2008, 01:31 AM   #1
Focusmad
Default Has anyone added a turbo to a 2.0Lt Duratec
Has anyone added a turbo to a 2.0Lt Duratec engine if so what did you do? a how much did it cost? and what gains did you get??[/SIZE]
Focusmad is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 01:34 AM   #2
Steffo
LPG > You
Steffo's Avatar
Slightly trailing... but Mazda should be shortly with the new MPS2. 2.0 Duratec Turbo, 172kW 313Nm. 1050kg. In the same chassis as a Fiesta...
Old 17-03-2008, 10:19 AM   #3
photn
AFF Post NAZI
photn's Avatar
there are turbo kits in the US (which you could probably get imported to AUS) try www.focussport.com or alternatively you could create on yourself for much less.
All you need is most probably:
small t25/t28 turbo ($500 from jap parts importer)
custom piping cost about another 500
Turbosmart Eboost 2 (boost controller, about 700bucks)
SCT flash (to tune your ECU 400bucks)
intercooler (depends on what you get and from ware)
Custom dump pipe about 500 bucks
install and a tune.
you are most likely to see about AT least 130FWKW, more if you do exhaust.
so there ya go. (btw i rounded up rather than down, so you MAY find the prices may vary and be cheaper, just depends on how good a haggler you are and how resourcefull and how mechanically minded you are.) ohh the more you do yourself the cheaper it is.
Old 17-03-2008, 12:33 PM   #4
BlackLS
yum
2.0 Duratec's stock rods are safe to about 8-9PSI.
There is someone in Hong Kong who's done this over a year ago to their Foc.
2005 LS Focus LX
250,000kms.
Old 17-03-2008, 08:07 PM   #5
fairmont1998
fairmont1998's Avatar
Surely you'd want to lower the compression too? 10.8:1 isn't too boost friendly.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2008, 10:30 PM   #6
Uni
spot on mr fairmont... lower comp ratios would be top of my list - low 9s/high 8s would probably let you run 8psi with a great deal of comfort.. a chunkier head gasket would probably do the trick, low comp pistons would be overkill.
Uni/.
Uni is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2008, 12:55 PM   #7
photn
AFF Post NAZI
photn's Avatar
Uni/.
not neccesarily,
You can happily run 7psi on the stock engine without any modifications apart from a tune.
if you want to put your mind at ease you can add a decomp plate or a pistons. but 7psi on stock engine is absoultely FINE.
Old 22-03-2008, 09:43 PM   #8
RJO89
EuroFordClub
RJO89's Avatar
Got some cash ??? :
http://performance3000.com/catalog/i...roducts_id=195
Far from stock... --- SOLD :
Old 23-03-2008, 11:34 PM   #9
Uni
faaark... the kit alone is going to be $10 000 before it's even fitted... better off selling and buying an XR5 for that sort of cash
Uni/.
Old 24-03-2008, 12:17 PM   #10
TITO
You are better off buying the kit from the U.S atleast it is all custom made,no guess work and it all fits.
install and a tune.
TITO is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2008, 12:26 PM   #11
RJO89
EuroFordClub
RJO89's Avatar
Personally, I'm with Uni, you're better off selling and getting an XR5 Turbo. At least that way you also get an extra cylinder and 0.5L!!!! Plus, a few simple modifications on the XR5 can turn it into a pretty brutal car, even more than it is stock.
Old 24-03-2008, 04:00 PM   #12
TITO
install and a tune.
Old 24-03-2008, 07:07 PM   #13
BlackLS
yum
Not really, the SCT flash box won't work with our ECUs, you'll need a custom tune from Dreamscience/CAPA (both SCT flash distributors).
Also its been reported by a Mazda3 owner that the custom exhaust manifold does not have clearance for the RHD steering rack.
2005 LS Focus LX
250,000kms.
Old 25-03-2008, 06:28 PM   #14
20focus05
I wanna XR5
20focus05's Avatar
Here is an aussie kit $3600
http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=018
Melbourne mob
just checked out their store and other kits are just over $4100 up to nearly $4800
they have duratec 2 and 2.3 ltr H beam conrods too
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 11:55 PM   #15
performance3000
Uni/.
Hi there! Saw you guys have had a look at our Turbo Kit. I don't want to go into it too much as I expect you're not allowed to advertise on the forum, but just for your information the price quoted there is actually for it fitted as it states. Even so at the current exchange rate it's about AUS$8700
Obviously if we're not fitting it (unless you guys fancy bring your car over LOL!) it will be less.
The Dreamscience unit used for mapping is actually an SCT unit, but rebadged for the European market under an international trade agreement.
Hope that clears some of it up for you guys, it's not quite as expensive as it may have first looked!
performance3000 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2008, 12:50 AM   #16
zetec
Zoom Zoom
zetec's Avatar
Another thing to remember if doing it properly. XR5 Turbo gets extra airbags, bigger brakes, bigger rims, better tyres, better steering rack, stiffer/lower suspension, better interior, better bodykit, factory exhaust, bigger engine, extra gear ratio.... and a factory warranty. That's a lot extra already included. If doing a Turbo install on your Zetec, consider at least better brakes and tyres to keep it on the road before any crazy bodykits or other bolt ons!
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
