04-03-2008, 09:28 PM | #1 | ||
Hey i need new headlight globes. The ones i have in my car now are 60/55W. Can i get any other more powerful ones say like 100/90W?
I wanna make sure i wont stuff my headlights and they aren't illegal. Thanks |
04-03-2008, 09:33 PM | #2 | ||
T3 TS50 075
There are special globes that you can get for the polycarbonate
lenses . Probably are illegal but if you have them adjusted right you would probably be ok ?
Cheers John My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw |
04-03-2008, 09:38 PM | #3 | ||
Prob jus be safer to stay with the standard Watt ones. Better that then geting in trouble with the cops
04-03-2008, 09:40 PM | #4 | ||
T3 TS50 075
You can get brighter lights that are still the same wattage
i nearly bought some for an EF my missus had before
04-03-2008, 09:53 PM | #5 | ||
When in doubt, GAS IT!!
go and look for Narva +50's .They are the same wattage as normal globes but 50% brighter. They come in most popular globe sizes. I have them in my AU wagon and they are much brighter than a standard globe.
Bushbasher
04-03-2008, 10:17 PM | #6 | |||
Teh Baest
He has had no trouble from coppers, they dont look that much brighter on regular, but high beams.. omg. But yeah, you can get brighter or higher intensity bulbs, even with the same power running through the filament, it's all to do with the surface area of the filament, efficiency and the temperature the filament runs at (Different bulbs have different spectral distributions with different temperatures) So yeah, just because they are higher power output does not necessarily mean they will be brighter. It is not a linear relationship between the two.
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
04-03-2008, 10:27 PM | #7 | |||
windsor user
they run hotter, so will tarnish the reflector, and probably even melt the lenses. i have seen the plastic shroud in the headlight cracked due to excessive heat from globes as well. au's have mint headlights, i cant imagine anyone wanting brighter headlights for regular on road use. |
04-03-2008, 10:34 PM | #8 | |||
04-03-2008, 11:09 PM | #9 | ||
Flairs - Truckers Delight
i agree with Luxo_8. Get good quality standard wattage Tungsram bulbs, ensure you have clean polycarbonate and align em right (drive up to a wall (preferably a brick/block one on flat ground) and adjust them using the little orange turny knobs(tm)) and you'll find you've got the brightest lights on the road this side of xenons.
04-03-2008, 11:14 PM | #10 | ||
we got the phillips bulbs for debs car (were around $60 for the pair in a blue box from repco)
they are very white in appearance and are very bright! being a fairlane its only single bulb for each light so the low beams are much brighter due to the new bulbs but the high beams are still the old globes so cant comment there
05-03-2008, 12:50 AM | #11 | ||
Fit a HID Bixenon kit. You can get them on ebay for around $150 and they should last around 5 years at least. You will not get better light, and no problems with lenses or reflectors - they actually use less power than "standard" replacement globes (35W compared to min 55W)
05-03-2008, 07:31 AM | #12 | |||
windsor user
if you feel confidant about doing some custom work, a retrofit shts all over a kit, let me tell you |
05-03-2008, 07:46 AM | #13 | |||
35watts at 12vdc = 2.916 amps 55watts at 12vdc = 4.583 amps |
05-03-2008, 12:07 PM | #15 | |||
The initial amp draw for the ballast to ignite the HID is massive though .. the ballast steps down wattage for the HID filament. I used to have a kit in my AU headlights ... then in aftermarket headlights. They were good in a way .... but very bad in others The standard headlight will not be able to control the beam properly causing glare for oncoming drivers ... you don't realise the stray bits of light until you drive up to a wall with them on. If you can ... get HID projectors (different from halogen projectors) ... and the full retro kit out of a wrecked Euro car .... so many to choose from ... even retro kits can be bought off eBay from the US .... you need to the timer and patience ... and skill to modify the existing headlights. I just went with halogen projectors inside my AU headlight (careof: The Dok) a few years back ... they have been great. For headlight globes ... nothing beats the Narva +50 for "legal" halogen globes ... I have tried many and did side by side tests on country roads ... the +50 had much better distance.
05-03-2008, 01:47 PM | #16 | |||
So at a constant 12 V source, moving from a 55W globe to something that uses 35W, means Amps reduces, not increases. ***EDIT*** Oops - looks like others beat me to it!
05-03-2008, 03:34 PM | #17 | |||
Cheers Matt. |
05-03-2008, 05:05 PM | #18 | |||
windsor user
here is a good little vid to show the spike on startup http://www.youtube.com/watch?v=NCqjSLUIkjk |
