Old 21-02-2008, 11:21 AM   #1
Sterling
Default shifter
how does the shifter on the 4 speed manual come out?
need an answer asap!!!
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 01:24 AM   #2
Royman
Hi, there should be a nylon bush at base of shifter that screws into gearbox, you will need to bend up locking tabs then use large shifter of multigrips to screw out whole unit (anticlockwise). Hope this helps
Royman is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2008, 12:20 PM   #3
Roy Rogers
Be carefull when you put it back in as it will cross thread very easy, this one of the main failing points on them.
President
Small Ford Car Club of NSW
www.smallfordcarclubofnsw.com.au
Roy Rogers is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2008, 09:19 PM   #4
Sterling
thanks sorry my internets been down and yeh it tried to cross thread but its back in now
