Old 19-01-2008, 08:00 PM   #1
JMO
JMO's Avatar
Default Thermostat
Hi. Just been reading a few threads on leaking thermostat housings as mine is currently doing so. I have just bought a new upper housing and have found that some people say it could also possibly be an o ring.
Its the by-pass pipe o'ring
Take the thermostat out, replace the seal, and also replace the thermostat by-pass pipe o'ring. When you take the old one out you will see its all squared.
There are 2 10mm bolts holding the by-pass pipe on the thermostat housing one is underneath the inlet manifold & one is on the thermostat housing.
What i wanted to know is where is this o ring located, ie. is it on the actual thermostat itself or elsewhere and what is the seal they are referring to.
Also, Do ford sell metal thermostat gaskets as i have heard the fibre ones are pretty crap.
Any help would be appreciated.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2008, 08:15 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Cant help with the 'O' ring bit, but did you make sure that ALL the old gasket is scraped off and if necessary file both surfaces flat.
Old 19-01-2008, 09:17 PM   #3
lostdude
lostdude's Avatar
The o ring your refering to is on the metal pipe going into the lower thermostate housing, is yours leaking in that area?.
I think ford don't actually sell a gasket for where the top thermostate housing meets the bottom one, what most people do and what i did was use those gaskets in a tube thing where you apply between the housings and then let it dry and once its dry it will form a rubbery gasket material.
here is my thread from before where mine was leaking.
http://www.fordforums.com.au/showthr...0&page=1&pp=25
Prev: 98 Au forte :
Now: 05 Wrx
lostdude is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2008, 10:29 PM   #4
JMO
JMO's Avatar
My leak is between the lower and upper thermostat housings and its also leaking from the small hose going from the upper housing to the overflow tank. I guess i won't change the o ring then as it's not leaking from the lower housing.
Thanks for all the help!
Old 19-01-2008, 10:43 PM   #5
JC
JC's Avatar
Have you checked the rubber gasket on the actual thermostat? If it's cracked, it will leak. Also, with the little hose, use a proper hose clamp, not the pinch type one and it should seal it up.
Ford Performance Club ACT
