Old 05-01-2008, 05:43 PM   #1
VCT_XR6_UTE
VCT_XR6_UTE's Avatar
Default Ute Wont Start
G'day guys, my ute has been loosing all the charge out of the battery the last few days, ide jump start it and it would run fine but when i turned it of it wouldnt start again.
So today i went and got a new $120 battery, the right type for my car. I droped it in put the terminals on went to go start it and nothing... turned it off then on and again nothing. the dash has gone weird aswell, the ODO doesnt come up and random lights light up, no engine or battery lights and there is a ticking noise coming from behind the dash and nothing electric works except for interier light which flashes in tune with the ticking noise.
im putting it down to the cumputer but with no experence in this area i really dont know, any help would be fantastic.
Cheers Guys
Marty
VCT_XR6_UTE is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2008, 05:50 PM   #2
b2tf
not here much anymore
b2tf's Avatar
The ticking noise is your starter motor trying to start the car. Im not 100% on this but I would check your starter motor and alternator.
2024 F150 XLT
Old 05-01-2008, 05:53 PM   #3
VCT_XR6_UTE
The ticking noise is still there even when the keys are not in the ignition
Old 05-01-2008, 06:45 PM   #4
b2tf
b2tf's Avatar
in that case its not the starter. have you got an alarm on the ute?
2024 F150 XLT
Old 05-01-2008, 06:52 PM   #5
VCT_XR6_UTE
Nah no alarm, as soon as i connect the battery a ticking noise comes from the areial, im stumped
p.s thanks for helping
Old 05-01-2008, 07:44 PM   #6
b2tf
b2tf's Avatar
The aerial noise is normal, if I disconnect my battery my ute does it too.
As weird as it may sound,leave it for a few hours then try to start it. You may have simply just drained the hell out of it and it needs time to charge up again (and yeah I did read you bought a new battery).
2024 F150 XLT
Old 05-01-2008, 08:13 PM   #7
howesy
howesy's Avatar
Sounds like you also may have an earthing problem. get a solid (not kmart) jumper lead and create a secondary earth making sure you bight into the terminal post itself and run it to the block. If you have an earthing problem this should make it start. If it doesn't change then I have heard of oxidisation issues in main harness plugs.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2008, 08:34 PM   #8
philstoj
philstoj's Avatar
Has the new battery got plenty of charge? mine did this when the battery went flat.
Old 05-01-2008, 08:39 PM   #9
amisupposed2b
Sounds like your alternator..
And for a short story, I had the same problem once, went insane trying to find out why. Then relized what I believe to be the alternator cable off...It was a male bimbo moment...
amisupposed2b is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2008, 09:54 PM   #10
BLU XR
BLU XR's Avatar
Check Fuses 1 To 10 Inside Car.these Supply Power To Smartsheild Security,via Bcm.if 1 Of These Fuses Blown Wont Crank.
If Smartsheild Light Flashes With Ignition Off And Faster With Key On,start Car With Another Key.if It Starts Must Recode Key.
From Gregorys Au Falcon Manual 1998-2002
BLU XR is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2008, 11:07 PM   #11
waggaclint
waggaclint's Avatar
sounds like a BEM problem to me...ive seen a far few AU,s do this.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2008, 11:16 AM   #12
VCT_XR6_UTE
What does this mean?
thanks for all the help guys, ill go try all your idea's and see what i come up with
Marty
