Old 25-12-2007, 01:41 AM   #1
kcej
2mny projects 2 lttl time
Default AU/AU3 different or same front suspension?
Can anyone tell me please.......I have just bought a 2002 AU3 with a hit in the drivers front wheel......
I need to know if AU or even AU2 upper and lower control arms are the same as AU3,
and also if the steering knuckle (The bit between upper n lower that holds the stub axle) is the same......
Oh.....also if the front guards are interchangeable
Local wreckers are telling me they have none for AU3, but I'm hoping earlier AU is same
Help Please......
Keith
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2007, 01:51 AM   #2
GK
Walking with God
GK's Avatar
Help Please......
Keith
Upper arms are the same, lower arms on the AU2-3 are different from AU1, I'm assuming knuckles are the same but you'd better get confirmation from another on that one.
Thinking, thinking!
I upgraded my AU1 wagon brakes earlier this year (my mechanic did) with AU2 bits and I didn't need upper bits or knuckles. In fact I'll say the knuckles are the same, but still wait for confirmation on it.
Front guards are interchangeable.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 25-12-2007, 02:02 AM   #3
kcej
Thanks again George
Can anyone confirm the knuckles?
Old 25-12-2007, 02:06 AM   #4
EvilChief
Boost Addict
the uprights are different due to swaybar location
upper arms are the same between all 3 series
lower arms are different
guards are the same (I think)
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 25-12-2007, 02:37 AM   #5
kcej
"the uprights are different due to swaybar location"
That would explain why GK didnt need new uprights......he was retaining his early swaybar........
I was trying to avoid paying $500 plus for new ones
thanks guys
Old 25-12-2007, 08:06 AM   #6
waggaclint
waggaclint's Avatar
give ford aring and see if the part numbers are same.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2007, 09:07 AM   #7
GK
Walking with God
GK's Avatar
thanks guys
I think we're mixing terms. Upright was different, upper control arm the same. I did replace the swaybar.
Hope that clears it up somewhat! LOL! Sorry for any confusion.
GK
Now gone!
On LPG
Old 25-12-2007, 10:30 AM   #8
FGII-XR6
FGII-XR6's Avatar
the things you need to replace when you are doing a brake conversion are the stub axles lower control arms and the stabiliser bar so that is what is different on the series one hope this helps
merry christmas
Old 25-12-2007, 02:46 PM   #9
Papa Smurf
Papa Smurf's Avatar
Upper control arms are the same now as BA-BF, if you DO go the NEW ones route, you MUST change both. The lower arms are AUII, AUIII and BA. The knuckles are different on AU1, AUII, III and BA are the same.
AU panels are all interchangeable (bonnets are different of course). Doors are all now BA doors but, you need to buy a plate if you use a BA door on AU's. The plate is for the Wiring to fit properly.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2007, 10:01 AM   #10
sly
Sly like a G6
sly's Avatar
Almost clear, but that last sentence is ambiguous.
Keith, any AU/BA/BF upper control arm will fit.
Lower control arm must be AUII or later as the sway bar mounts are different to AUI.
Steering knuckle (AKA "stub axle", "upright" or "spindle") must also be AUII or later as the caliper mounts are different to AUI.
Ideally you would get the lower arm and steering knuckle as a set & still joined but if you can't, you can get them from different models between (and including) AUII and BF.
Also check the sway bar chassis rail brackets (the black ones, not the D brackets) on both sides of the car. The brackets should have straight sides & should be replaced if bent or bowed. I got a BA front suspension to upgrade my AUI front brakes. Although the donor car had supposedly been rear-ended both these brackets were bent. If your car has taken a hit to the front wheel I wouldn't be surprised if yours are bent too.
Sleeper, anyone?
Old 27-12-2007, 11:52 AM   #11
GK
Walking with God
GK's Avatar
merry christmas
The stabiliser mounts are also needed, make sure you grab them also!
GK
Now gone!
On LPG
Old 27-12-2007, 08:52 PM   #12
Papa Smurf
Papa Smurf's Avatar
Yes, sorry about that. My eyes were not the best when I posted
Old 28-12-2007, 01:45 AM   #13
kcej
Thanks guys for the extra info.......much appreciated......
Also, for the information of others who might be watching....I'm told today by a local wrecker that AU1 guards differ from AU2 & AU3 in the area of the side blinker
Thanks again.......Keith
