Old 06-12-2007, 05:07 PM   #1
cthorange
Default brake failure light
i was driving about today and i was going down a hill and i thought to myself wow the brake feels really light all of a sudden and it doesnt seem to be doing anything, then the brake failure light came on (!) for about 2 seconds then went off and then braking was back to normal and has been for the rest of the trip.
just wondering if that indicates a problem coming on or what could cause that, its an AU series 1 , no ABS.
cthorange is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2007, 05:11 PM   #2
Mechan1k
Mechan1k's Avatar
no leaks in the system????
Either an issue with brake booster or master cylinder on it's way out.
I'd be getting a mechanic to check it out straight away.
Next time the light might just stay on ... and you won't have any brakes at all.
Old 07-12-2007, 09:59 AM   #3
cthorange
yeh i checked the fluid level, its a bit over max, so no leaks. i rang my mechanic this morning and he said he'll take a look at it today, and he also said the master cylinder may need replacing
Old 07-12-2007, 11:04 AM   #4
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
So will your Wallet when its done !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2007, 11:16 AM   #5
347 mont
347 mont's Avatar
Not as empty as it might be if you damage property or worse yourself or someone else, You gotta do what you gotta do and you must get this checked out.
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2007, 01:40 PM   #6
TE50 027
Tickford Tough
TE50 027's Avatar
Yeah, my old EF did exactly the same things a few years back. Driving to the mechanic the next day went to hit the brakes only to find the pedal went to the floor and no brakes (God bless handbrakes). Was the diaphragm in the brake booster. Cost a couple of hundred to replace. Did the master cylinder not too long after. Get it checked and replaced ASAP.
Sparkling Burgundy T1 TE50 Build #027 - SOLD
TE50 027 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 10:32 AM   #7
cthorange
yeh i took it down to the mechanic on friday who chekced it out, when you put your foot on the brake, after awhile it slowly starts to sink to the floor. if you release the pedal then the tension comes back then starts sinking again.
so its going in tomorrow to have the master brake cylinder replaced, he said it would be about $200 (probably work out to be a bit more though) which didnt seem to bad?
