Old 24-11-2007, 07:34 PM   #1
Falcon87
Falcon Unbelievable
Falcon87's Avatar
Default how do you remove spot welding from the rear passanger 1/4 panel on an AU sedan?
Wats the easiest way to remove spot welding from the rear passanger 1/4 panel on an AU sedan?
Falcon87 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 08:03 PM   #2
wodahs
wodahs's Avatar
ither drill them out or chisswl them of
drilling is alot neater but your left with a hole to fill but ...
if your replacing one of the panels you can place a strip behind or the new pannel behind and weld up the hole and grind back
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 09:54 PM   #3
Falcon87
Falcon Unbelievable
Falcon87's Avatar
Will it be hard to fit another rear 1/4 panel on?
Old 24-11-2007, 10:01 PM   #4
wodahs
wodahs's Avatar
as hard as someone rebuiding a motor when theyve never done it before
and you need some more tools than just a drill and some spaners
you need a mig and dont rush it , if you try to weld to much at once youll warp the panel
