Old 23-11-2007, 10:37 AM   #1
StealthAu
Default AU 1 I6 coil packs
Hey all, I need a new coil pack for the au. Was just wondering were the best place to get them from would be? and what brand?
Old 24-11-2007, 07:40 AM   #2
StealthAu
Just having a look on the net, are the Motek items any better then the factory ones?
Old 24-11-2007, 09:05 AM   #3
au2sw
Blown 5L coming
au2sw's Avatar
dont go with champion....im on LPG and have had 2 fail in the last month. when the next one fails, ill be going the more expensive options hoping that more expensive means better quality.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 09:55 AM   #4
Burley
CRE.87V
hey mate i picked up a gen bosch one on ebay for 86 including postage.....mine is a 99 au xr6
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 01:12 PM   #5
StealthAu
Yeah I've seen the genuine items on ebay, just wondering if there was an aftermarket item which is better
Old 24-11-2007, 02:16 PM   #6
waggaclint
waggaclint's Avatar
never heard of those who makes them?
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 02:59 PM   #7
StealthAu
No idea, I'm guessing Motek
Old 24-11-2007, 09:11 PM   #8
FS5
hey,stockoau do you have a link to the ones your looking at?
thanks mate
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2007, 10:10 PM   #9
StealthAu
somewhere on here
http://www.motec.com.au
Old 24-11-2007, 10:11 PM   #10
StealthAu
And don't ask me were I got Motek from, I ment Motec
Old 24-11-2007, 10:43 PM   #11
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
i was going to say that , but thought otherwise ..
Cant you just use a Bosch GT40R , or Contact MSD or Rocket to see what can be Adapted to the AU Specs ?
What about Fireball , ive seen that setup on an EL , so it should work in the same Principle as an AU ..
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 08:36 AM   #12
FS5
found it on page 37 of there cataloge,by the looks of it it says there a denso item
Old 25-11-2007, 09:58 AM   #13
StealthAu
Whats Denso?
Old 25-11-2007, 10:21 AM   #14
JC
JC's Avatar
Daniel
EL uses a dizzy, EF & AU use coilpacks, and you can't just swap them over between.
Denso is Nippon Denso - they make plugs, coil packs etc mostly for Japanese cars, but also for Holden and Ford. They make a lot of the OEM stuff. If you get platinum spark plugs from Ford, chances are they are made by Denso.
www.denso.com.au
Ford Performance Club ACT
Old 25-11-2007, 10:31 AM   #15
StealthAu
I think EF and AU1 coil packs are the same
Old 25-11-2007, 10:36 AM   #16
JC
JC's Avatar
Kind of, but not really. I think the plug ends are the same, but the coil packs are all new for AU1 - the reason they got rid of them in EL was that the EF ones were no good. So i wouldn't go using an EF coil pack in an AU, but an AU coil pack in an EF might be a good option, but will probably mean chopping and splicing wires (Ford tend to change the electrical plugs between series, for some reason)
AU2 are different again (AU1 have "inny" plugs onthe coil pack, AU2 has "Outies").
Old 25-11-2007, 10:54 AM   #17
Mechan1k
Mechan1k's Avatar
Speak to Macarthur Parts Plus if you need some ... I got my AUII coil pack from there ... was like new ... I'm sure FTG ahould have one ... or know where to get one for you.
Old 25-11-2007, 11:00 AM   #18
StealthAu
I'll just get a new set off ebay. Really couldn't be stuffed replacing them though.
Old 25-11-2007, 12:25 PM   #19
JC
JC's Avatar
It's pretty easy - 2 x 7mm bolt/screw things, unclip electrical plug & leads, remove and replace.
Old 25-11-2007, 09:07 PM   #20
sly
Sly like a G6
sly's Avatar
Does that mean you can put an AU2 coil pack in an AU1 as long as you change plug leads as well? Or are the mountings different as well?
Sleeper, anyone?
Old 25-11-2007, 09:36 PM   #21
StealthAu
Can you get to it without removing the manifold?
Old 25-11-2007, 10:45 PM   #22
waggaclint
waggaclint's Avatar
yes you can.....i just remove air intake and use a long extension to get to bolts pretty easy....
