Old 12-11-2007, 03:15 PM   #1
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Inhibitor Switch
Hi All
you know the inhibitor switch on the passenger's side of your automatic, whitey cream in colour, what does it do?
cheers
Old 12-11-2007, 04:40 PM   #2
peterban
AULTD
peterban's Avatar
It inhibits the starter from starting whilst in gear.
The car will only start in park or neutral and if faulty will stop the car starting at all.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2007, 05:16 PM   #3
Mr Hardware
oh
right
hmm, i thought it was something more complex than that
can't see the forest for the trees
Old 12-11-2007, 06:07 PM   #4
FGII-XR6
FGII-XR6's Avatar
that is the primary function but AFAIK it also gives the signal telling the ECU (and the cluster in higher models) what gear is selected
Old 13-11-2007, 08:30 AM   #5
TwistedEL
TwistedEL's Avatar
Yep it does both
It actually has two separate circuits, one is the inhibitor switch and the other is a series of resistors which tell the ECU / Cluster what gear you are in.
Old 14-11-2007, 09:26 PM   #6
BLU XR
BLU XR's Avatar
WHY ARE U ASKING.TO CHECK IF ITS STUFFED PUT INTO 1st DRIVE IT, IF IT STILL CHANGES THRU THE GEARS ITS STUFFED IF IT STAYS IN FIRST AND U NEED TO CHANGE GEARS ITS OK.
BLU XR is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2007, 12:28 PM   #7
twr7cx
Member
twr7cx's Avatar
Mine doesn't do this, but is still buggereed.
With mine sometimes I can be Park or Neutral and still can't start the car - seems to think it's still in gear. My old boy made a bypass for it so all is good with the world now.
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
