Adams Polishes
Old 13-10-2007, 07:21 PM   #1
kenz
BOSS Pilot
kenz's Avatar
Default ticking noise ?
Hey guys, my ute has developed a ticking noise under acceleration. It kinda sounds like when you put a zip tie or the like on the spokes of a pushy when you were a youngin. The higher the revs get up the faster it ticks but only does it when im accelerating. Any ideas?
Thanks
Luke
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 07:41 PM   #2
atec77
Thanks
Luke
More information about the motor , is it a wheezer ? ( if so the answer might be a bad skirt)
Old 13-10-2007, 07:57 PM   #3
svo347
AFF's 1st DM.......
svo347's Avatar
Either timing chain rattle or detonation
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 13-10-2007, 08:01 PM   #4
burnz
VFII SS UTE
burnz's Avatar
a cracked header
GO SOUTHS
Old 13-10-2007, 08:38 PM   #5
schuldiner
could be a sticky lifter like mine there is some additive you can pour in with the oil it settled mine down some.
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 09:00 PM   #6
b2tf
not here much anymore
b2tf's Avatar
leaking exhaust/loose header bolt etc
2024 F150 XLT
Old 13-10-2007, 09:05 PM   #7
HLC
Audi S3
on the money.
Old 13-10-2007, 09:09 PM   #8
walker
walker's Avatar
yeah I'd say a leaking exhaust manifold for sure, try re-tension the bolts if that aint fix it try replace the gasket,
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 09:12 PM   #9
goodjjp
If you replaced brake pad recently... maybe the mechanic forgot to put
the clip on the caliper so u r getting -0- clicking noise ...
goodjjp is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2007, 06:19 AM   #10
cossy
Talking
No its the two pice exhaust header my au had that ticking noise under acceleration drove me nuts i replace gasket in a week it started again so the only thing was to get it replaced now on ticking I dont need to turn the raido up louder so i cant hear it
cossy is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2007, 10:36 AM   #11
kenz
BOSS Pilot
kenz's Avatar
And we have a winner! It was the bottom bolt on the 6th pipe was loose as, tightened it up and it sounds as good as new again
Thanks
Black BAII XR8 Ute
Old 17-10-2007, 08:19 AM   #12
Cam
Stroking it...
Cam's Avatar
hrmmm would this be the most likely cause on a V8 as well? I have a ticking that seems to be getting worse.. I can only hope its just a loose bolt / dead gasket!
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
