Old 06-08-2007, 05:42 PM   #1
BlacklistedXR
Default Camber Adjusting Kit
hey ,
i am looking to lower my AU2 XR8 on superlow king springs and am unsure how many camber adjusting kits i need. i thought i would only need one but after talking to a few people i think i may need to buy two. I want to have a competitive track car that will be able to handle well. all help will be much appreciated.
cheers
chris.
BlacklistedXR is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2007, 06:09 PM   #2
Mack 6
SUMP PLUG
Mack 6's Avatar
I had superlows put on and I bought one K-Mac Camber Kit for the fronts. There is also a nolathane setup which is a bit cheaper.
I can get a fair bit of adjustment out of them, just make sure you re tighten them after 100 odd km's.
I have live axle so didn't ask about a set for the rear if you have IRS, but I'm guessing they should do something there too!.
Mack 6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2007, 06:10 PM   #3
blackers10
blackers10's Avatar
there is ALSO a new strange pedders one from memory
and fulcrum also do a shim type one
you need to purchase 2 kits of the fulcrum one as its 1 kit per side
(you need 4 brackets)
alignment shops have a bundle of shims they use rather than having to buy loads more..
Old 06-08-2007, 06:17 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
Go the kmac kit mate.. fully adjustable and alot easier by way of a ratchet mechanism I have a set on my XR......
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 06-08-2007, 06:31 PM   #5
BlacklistedXR
how much is it for a k-mac kit and where can i get one from? i was told that i would need two kits as my car has two pivots each side and 1 kit only replaces 1 pivot on each side. do i need a kit for the back? my car is irs.
Old 06-08-2007, 06:32 PM   #6
blackers10
blackers10's Avatar
if its an XR i beleive htey had the longer bolts already in the rear..
i dont believe there is any more "kit" you can buy to adjust the rear any further
but unless its in the weeds you should be fine
Old 06-08-2007, 06:40 PM   #7
Sledgehammer
Sledgehammer's Avatar
Another vote for the K-MAC kit
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
