Old 25-06-2007, 06:37 PM   #1
AUI99
AUI99's Avatar
Default Spooled 4.11 diff for my AU?
I own an AU forte non irs and i need a new diff!
I found this for sale EL Spooled 4.11 diff should i buy this and have it installed??????
What will it be like on the road? Or should i just get a normal diff????
Thanks...
More info...
Description: Spooled 4.11 diff . It is in a EL Sedan..
It has new 31 spline axles with new seals and bearings on Axles.
The crown wheel and pinion have new bearings and new pinion seal.
New hand brake shoes 15,ooo km ago.
It has new rotors as well ( put on Easter Friday with new pads).
He wants $600- for it! Is this okay?
AUI99 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 07:04 PM   #2
AUI99
AUI99's Avatar
Help anyone?
Old 25-06-2007, 07:07 PM   #3
JC
JC's Avatar
A spool or mini spool is fine for the drags, but not an everyday proposition.
Ford Performance Club ACT
Old 25-06-2007, 07:09 PM   #4
stiddy
stiddy's Avatar
I wouldnt do it.
A spool on the street is a silly move, and lethal in the wet.
Plus, I think the EL diff is Different to the AU diff?
Old 25-06-2007, 07:10 PM   #5
FGII-XR6
FGII-XR6's Avatar
a spooled diff is illegal for road use and would be a pig to drive it would skip around corners a spool is only really good for strip use aqs it is a straight line. The 411 gears would give good acceleration but you would need to put a different centre in either a single spinner or better still an LSD also you would need to use your old housing and axles as the AU has a different offset
Old 25-06-2007, 07:14 PM   #6
AUI99
AUI99's Avatar
I've got a single spinner atm...Would the 4.11 gears consume more petrol?
Old 25-06-2007, 07:16 PM   #7
stiddy
stiddy's Avatar
On highway yes, cause you'd be crusing at a higher RPM.
Around town probably not.
Old 25-06-2007, 07:16 PM   #8
JC
JC's Avatar
Yes - your car will be reving approx 30% higher for the same speed.
Old 25-06-2007, 07:19 PM   #9
AUI99
AUI99's Avatar
So the verdict is no?
Old 25-06-2007, 07:21 PM   #10
stiddy
stiddy's Avatar
lol yes, dont do it. Well atleast not the spool part.
the 4.11's are upto you, its got its pros and cons like most things.. maybe get an LSD with 3.9's instead.
Old 25-06-2007, 07:23 PM   #11
FGII-XR6
FGII-XR6's Avatar
your choice really but the only thing you'll be able to use is the gears (take this into account when considering price) you will use more fuel but the car will go harder off the line
Old 25-06-2007, 07:26 PM   #12
AUI99
AUI99's Avatar
I'd love for the car to go harder off the mark lol...But hmmmm i might just get a normal diff...Or mine recoed!
Old 25-06-2007, 09:16 PM   #13
private9
www.TUFFCARPARTS.com
private9's Avatar
It's a good price for a good setup!
Having said that, I absolutely hate locked diffs in street cars. Having owned one for a short while they are absolutely horrid things to drive. They're a laugh for about the first 5 minutes, and then the rest of the time you're car is a plough understeering, snap oversteering pig of a thing which will destroy rear tyres, destroy your bushes, snap suspension arms and generally turn your car into a P.O.S.
I snapped the arms clean off the diff in mine simply trying to do a very wide u turn. I'll say it again, P.O.S!
Can you tell I hate locked diffs?
Old 25-06-2007, 09:29 PM   #14
AUI99
AUI99's Avatar
I get ur drift lol!!!! I'll go a normal diff then!
Old 25-06-2007, 09:37 PM   #15
FGII-XR6
FGII-XR6's Avatar
what I did in mine was put in an XR6 non IRS diff that gives you 3.45 gears and LSD launches better and is not over the top you need to replace your speedo gear with a grey one
Old 25-06-2007, 09:42 PM   #16
OED666
OED666's Avatar
get a lock-rite centre for your diff. they rule. lsd's are ghey, (i am talking from experience).
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 09:48 PM   #17
4VCLEVO
XA GT
4VCLEVO's Avatar
I had a 4.11 spooled diff in my EA. The 4.11s do somany turns to 1 that they dont skip that much at all compared to a spooled 3.23 that I had in the same car. Fuel consumption increased as much as the leterage per 100km that you normaly get around town, the highway leterage became the same. So for me I was getting 400km to a tank with an engine producing 215kw, with the same engine and standard 2.92 gears I would get 550 odd km to a tank.
4VCLEVO is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 10:00 PM   #18
FGII-XR6
FGII-XR6's Avatar
i guess your missing the main point it is not legal to have a spooled diff on the road. they are dangerous for street driving and damage the roads when they skip and bounce around corners. a diff (they are called a differential because they allow the wheels to turn at different speeds) is intended to allow a car to corner. Install a spool and it is no longer a diffential but a straight axle great for a drag strip but useless for anything else
Old 25-06-2007, 10:13 PM   #19
4VCLEVO
XA GT
4VCLEVO's Avatar
I was just pointing out that with 4.11's they dont skip much, realy they only do it if you do a tight u turn. I used this center for 2 years and about 40000km's and never had an issue with it or the police. Yes they might be illegal but so are most modifications we do to owe cars, you just have to make a decision which mods you want to risk the police finding out about.
Old 25-06-2007, 10:36 PM   #20
private9
private9's Avatar
Out of curiosity OED, what's a setup like that worth?
Old 25-06-2007, 11:30 PM   #21
FGII-XR6
FGII-XR6's Avatar
some mods should stay on the track / strip this is like puting slicks on a road car it's a non road mod and saftey dictates it should stay there even circuit racers wouldn't use a spool they are for straight line use
Old 26-06-2007, 08:35 AM   #22
OED666
OED666's Avatar
well if you already have an open centre, you just buy the lock-rite from 4wd systems for $610. you can fit it yourself if your reasonibly capable with tools. lock-rite FTW!!!
no more one wheelers. they also behave extremely well behind autos.
Turbo Barra ED 4L
Old 26-06-2007, 08:55 AM   #23
private9
private9's Avatar
Are they like an air locker where you manually select it to lock, and then deselect when you're done?
Old 26-06-2007, 09:17 AM   #24
OED666
OED666's Avatar
they cant be turned off so to speak. it locks under load, either accelerating or de-accelerating.
eg. if your pulling out into a T intersection, if you accelerate in a straight line, its locked, but back off the juice, turn the wheel and roll around its not locked. then back on the juice its locked. but if your parking slowly and you need to accelerate lighty it will lock.
Rollin has one. before he converted his car to a manual the other week, his car behaved so good with the auto and a lock-rite. you wouldnt know it had one.
Turbo Barra ED 4L
Old 26-06-2007, 09:38 AM   #25
private9
private9's Avatar
Hmmm, so a bit like a less savage detroit locker then?
Old 26-06-2007, 10:15 AM   #26
OED666
OED666's Avatar
pretty much... and much cheaper.
Turbo Barra ED 4L
Old 26-06-2007, 12:01 PM   #27
Mark351
Built Ford Tough
Mark351's Avatar
Behaved when it was auto, now that it's manual?
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 12:39 PM   #28
OED666
OED666's Avatar
its still pretty good, way better than a mini-spool. it was just really strange driving it when it was an auto. you just wouldnt know it had a lock-rite.
Turbo Barra ED 4L
Old 26-06-2007, 02:28 PM   #29
gozza
gozza's Avatar
ahem :ymca:
gozza is offline   Reply With Quote Multi-Quote with this Post
