Old 01-06-2007, 10:14 PM   #1
tickfordguy
TICKFORDGUY
Default revs dropping
dont no what it is but when u come to a stop the revs drop down a 200 rpm or so then the car shuders then go back up also when reversing so far tried plugs leeds clean tb and idle unit just had the auto full power flush and service brand new pod filter and still doing it could it be o2 sensor or coil packs
tickfordguy is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2007, 11:00 PM   #2
philstoj
philstoj's Avatar
Check your fuel system
Old 02-06-2007, 09:38 AM   #3
Burley
CRE.87V
different car i know...but my fiancees tx3 laser was doing this as of yesterday...got my mechanic to clean injectors and tb using some machine.....took hour to do.....even got rid of the lag as well as the rough idle.....all other mech charge 220 for this service...these guys done it for me for 100 bucks...so there would be a fuel prob as philstoj said...hope this helps
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 01:47 PM   #4
CMYAU3
Tyre Shredn
CMYAU3's Avatar
this happened to me when u stop the revs drop and almost stall then go up then down and once it even stalled on me. this solved my problem take off the air intake from the throttle body and spray some throttle body cleaner in there and give it a clean. my had some black gunk in it.
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 02:35 PM   #5
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
My ute did this after being parked up for a while, took it on a long drive and problem solved...i'm guessing it was a bit of carbon build up on the plugs or something similar
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 02:49 PM   #6
burnz
VFII SS UTE
burnz's Avatar
engine type would help
but it sound's like vaccuume leak
intake gasget (moreso v type config)
split rubber plumbing,maf,map,gearbox,egr
listen for a weak whistle(around manifold,and plumbing)
GO SOUTHS
