Old 24-05-2007, 08:13 PM   #1
AUTickford
XD197
AUTickford's Avatar
Default Will my trans cooler affect engine temp?
Just got a derale trans cooler for the au v8 and its bigger than what i thought,size is 250mm by 350mm.Just wondering if any of you forum members have fitted one and did it cause the engine temp to get hotter because of the size[i thought it was gonna be half the size,like the one on my eb v8]Hopefully it wont affect the airflow through the rad but let me know what you think,cheers.
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 08:14 PM   #2
Casper
Contributing Member
Casper's Avatar
shouldnt make any difference at all.
Older, wiser, poorer.
Old 24-05-2007, 08:20 PM   #3
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
i have one on my series 3 xr8 and it dosnt run hot at all and it definitly gets driven hard enough to heat up. So you shouldnt have any probs
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 08:46 PM   #4
au2sw
Blown 5L coming
au2sw's Avatar
the radiator actually draws cool air up from the lower air dam in the front bar via the spliter (the black plastic piece that sits at the bottom of your front bar) the thermo fans help to draw the air up so the cool air doesnt come directly through the oil cooler and a/c evaporator (the silver radiator looking thing in front of your radiator) so it will make no difference to your engine temperature at all.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 12:30 AM   #5
AUTickford
XD197
AUTickford's Avatar
Thanks alot for the comments guys i feel more confident now,CHEERS.
Old 25-05-2007, 05:04 PM   #6
Umineko
Karasu
Umineko's Avatar
The standard transmission oil cooler runs through the header tank of the radiator anyway so even if the airflow passed directly through the new cooler and on through the radiator it should have no effect at all, if anything you'll probably find the engine may run slightly cooler as the engines coolant is no longer taking heat from the transmission as well
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 09:35 PM   #7
mik
mik's Avatar
i have the same , i dragged a caravan melb to brizzy and back in summer to the relo`s did the tourist thing, no noticeable tempreture difference.
