Old 23-05-2007, 06:44 PM   #1
josh_hartman
Default S2/3 dash in S1. Anyone Done This?
has anyone here done this, if so does it work or do you just need to change the usual 4 wires?. will it show up DTE?
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 06:48 PM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
i have. i put a s2 t-series dash in a fairlane....few probs...which usual four wires need changing?????
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 06:50 PM   #3
josh_hartman
umm abs light, dim light and right hand indicator. thats all i can remember. thats for fortes and stuff. what problems did you have?
Old 23-05-2007, 06:51 PM   #4
KR1STO
KR1STO's Avatar
oil pressure not registering, trip computer not registering and the drivers door not registering...everything else works great...
see my car here:
[SIGPIC][/SIGPIC]
Old 23-05-2007, 06:54 PM   #5
josh_hartman
oil pressure. i thought that would work. are you talking about the gauge or light? did your old dash have a gauge?
Old 23-05-2007, 06:56 PM   #6
KR1STO
KR1STO's Avatar
yeah the old dash had the gauge... its got me beat.. i guess its just a couple of wires...i hope.
see my car here:
[SIGPIC][/SIGPIC]
Old 23-05-2007, 07:30 PM   #7
FGII-XR6
FGII-XR6's Avatar
ok it will work if you do the usual 4 wire routine but and this is the big but the oil gague is only a dummy gague on the S2 and uses a switch and not a sender so it shows 3/4 or zero it looks like a gague but is realy just like an idiot light if you still have a sender in the gague will register zero. i put a tickford cluster in my S3 SR and put a sender in thought my cluster was roo**d but eventually worked it out . btw you can't go S1 into a S@/3 the stereo volume will shoot up to max and deafen you : it is something to do with the speed alaet wiring even if SA is not fitted good luck
