Old 21-05-2007, 09:02 AM   #1
Robe
Default Indicators Freeze
For the second time in a few hours I have had my turn indicators stop blinking.
The correct turn signal on the dash lights up but does not flash. All the globes are OK.
If I turn the ignition off and on again everything is fine.
Is the car telling me that the blinker can is on its way out?
Are there are special dramas in replacing this unit?
Thanks
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 09:39 AM   #2
stiddy
stiddy's Avatar
Its not the blinker.. its the relay in the fuse panel. the panel near your right knee under the dash, open that up, and its the relay on the bottom right.. give it a tap and it will start working. big black square.. if you put your fingers on it you can feel it ticking..
had the same problem with mine.. i flogged a relay from the wreckers.
Old 21-05-2007, 12:48 PM   #3
Peuty
Afterburner + skids =
Peuty's Avatar
Yep exactly what Stiddy said! I would take it one step further and take the relay out, give it a bash and then putting it back in.
Daniel
Oo\===/oO
Old 21-05-2007, 01:32 PM   #4
The Monty
Just slidin'
The Monty's Avatar
I think they are about 15 bucks new, so worst case scenario, its a cheap as fix.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 21-05-2007, 07:59 PM   #5
chief
FTF Club Moderator
chief's Avatar
This problem happened to me. It was the relay.
Albert Einstein:
Fords in the Park 2010
Old 22-05-2007, 08:39 AM   #6
Robe
Thanks Stiddy. Sweet!
I knew one of my AU brothers would tell me the fix.
I was so pleased that I actual paid for a new one. :
Rob Ewart
www.VRRDA.com.au
Old 23-05-2007, 10:12 AM   #7
Baboon_AU
Baboon_AU's Avatar
the genuine ford ones aint 15 bucks new, they retail for 70 bucks. with my discount i got it for $46.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
