Old 20-05-2007, 11:27 PM   #1
Norton
Tuned by HPF
Norton's Avatar
Default Need a quick response - Air Temp Sensor Help
Hi Guy's,
I need a quick answer on the best way to install the Air Temp Sensor for my Supercharger install.
If you can help let me know.
I've posted in another area but I thought there may be some AU folks who can help.
http://www.fordforums.com.au/showthr...14#post1484114
BF XR6T
Stock....For Now
www.aufalcon.com/norton :
Norton is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 12:14 AM   #2
JC
JC's Avatar
In the intake, same as normal. I cant see hwy it would be any different.
Ford Performance Club ACT
Old 21-05-2007, 12:22 AM   #3
Norton
Tuned by HPF
Norton's Avatar
Just concerned about the added pressure (Under Boost). Don't want it to pop out.
BF XR6T
Stock....For Now
Old 21-05-2007, 12:27 AM   #4
JC
JC's Avatar
I did think of that, but it's got a small barb on it, so should be enough to hold it tightly i the factory position. I've also realised you are metal piping - you need to drill a hole large enough to accept the barb, then use a rubber grommet in the hole to keep the sensor from popping.
Or maybe just fit it into the silicon joiner, that should be easy enough to drill a hole slightly smaller than the sensor probe, and supple enough to accept it, yet not spit it back out under boost conditions.
