Old 19-05-2007, 07:00 PM   #1
drracing108
au1xlsv8
Default intake manifold?
probably a stupid question, but is it not a good thing to use the standard 5tlr efi manifold wen the engine worked? cheers
au1 xls tarmac rally ute, soon to be 8tb manifold, efi, alloy headed **363ci** windsor, REBUILT, dart sportsman block and big solid roller cam EDITED
drracing108 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 11:03 PM   #2
b2tf
not here much anymore
b2tf's Avatar
yep, no worries at all. if you feel like spending money though, edelbrock and trickflow make manifolds to suit.
2024 F150 XLT
Old 20-05-2007, 10:28 AM   #3
drracing108
au1xlsv8
cheers mate
Old 20-05-2007, 10:38 AM   #4
xr8ute
Back on the road
xr8ute's Avatar
depends on what you mean by "worked"...what heads, what cam, and what rpm are you shifting/redlining?
the std intake can support some pretty decent power, but ultimately the long runners hold it back at very high rpm.
the lower needs to be ported to flow as much as the upper, they can flow up to 250cfm with a ported lower (and about ~200cfm stock).
runner length will hurt power above 6000rpm
Old 20-05-2007, 01:42 PM   #5
drracing108
au1xlsv8
so i can get work done to the stock manifold??
Old 20-05-2007, 01:54 PM   #6
xr8ute
Back on the road
xr8ute's Avatar
Yep. The lower intake manifold has runners that taper down in size to be much smaller than even the std GT40P intake ports.
The lower can be ported to allow it to support much better flowing cylinder heads (up to 250cfm).
The only thing that is not so easy to modify is the runner length, so it is not suitable for a combo that wants to make peak power at very high rpm (6000rpm+).
Old 20-05-2007, 02:01 PM   #7
drracing108
au1xlsv8
what would u suggest for decked heads and a fairly big cam??
Old 20-05-2007, 02:19 PM   #8
xr8ute
Back on the road
xr8ute's Avatar
depends on which heads are being "decked" and how "fairly big" the cam is ;)
If you are keeping the std GT40P heads (without any porting), then I would keep the std Explorer intake and not even bother porting the lower...
Old 20-05-2007, 02:38 PM   #9
drracing108
au1xlsv8
yeh we will see, i havent even spoken to the engine builder down south yet, you might know, how much do u rekon it would cost for head work (new heads i guess) big cam and kit and forged pistons and rings? jus a rough estimate....
Old 20-05-2007, 05:05 PM   #10
mcflux
mcflux's Avatar
how long is a piece of string?
Check out the Windsor section http://fordforums.com.au/forumdisplay.php?f=11 for a heap of info on heads, manifolds, cams, etc...
Old 04-06-2007, 07:47 AM   #11
Eroda
what i want to know with ported edelbrock lower, and ported GT40Ps with larger valved etc and a standard au220cam, would i be better running the edelbrock upper ported to 75MM for a 75MM TB or would porting the factory manifold to 75MM and to Match the Lower be just as good
Eroda is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2007, 03:12 PM   #12
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Thats the weakest link in what you are doing, save the money on the 75mm TB and buy a nice new cam for it. Then it will compliment your bigger valves and head work.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2007, 10:40 PM   #13
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
I agree with Neisha. I ported my lower and my standard gt4op heads and it made a huge differance to the low down torque and hi rev power. 70mm TB is more than enough unless your running a big stroker or forced induction.
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
