Old 06-10-2006, 01:24 PM   #1
frost
frost's Avatar
Default AUS2 not starting via key
Hi,
Recently just repaired an AUS2 Tradesman ute, the fuse's were screwed and the front of the motor ******, so we put an AUS1 motor in, and changed it to an AU S1 Loom, keeping the S2 ECU.
Now it wont start via the key, it will start if run a wire from the relay to positive but yeah.
Any Ideas?
frost is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 01:31 PM   #2
JC
Miami Pilot
JC's Avatar
You need to get the ECU coded to the new BEM. Only Ford can do this.
Ford Performance Club ACT
Old 06-10-2006, 01:45 PM   #3
frost
frost's Avatar
Is this even with the orginal ECU out of the car before the motor swap and the same key and BEM?
Basically we swapped motors and the loom, nothing else
Old 06-10-2006, 03:11 PM   #4
frost
frost's Avatar
ok fixed, it was a wire under the dash had been cut, well a few, it must of had an aftermarket alarm in it, and they have ripped it out before it went to auctions, thanks for your help anyway JC
Old 06-10-2006, 04:00 PM   #5
I6corp
Was V6corp
I6corp's Avatar
But because of build dates etc...,
isn't it illegal to put an older motor, in a newer car?
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 05:07 PM   #6
frost
frost's Avatar
everything is the same execpt engine number, it all works now,
Old 06-10-2006, 06:13 PM   #7
bodes-sh
it's not illegal as long as the motor meets the emission requirements of the year of car that it is being put into...im pretty sure there were no emission changes between au1 and au2...someone correct me if im wrong
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2006, 07:31 PM   #8
frost
frost's Avatar
Put it this way, everything is the same between AU1 and AU2 motor in the way of part numbers just the orginal one was stamped 00 this one is stamped 99 and it has a differnet number
If anythings going to stop it it will be the VIV
