17-07-2006, 01:34 PM | #1 | ||
Bseries hardcore
I have an annoying buzzing sound from my system in my car, it goes with the revs of my car and now its really annoying and you can always hear it, ive ran the power cable and speak cable seperate, ive seperated the RCA's and some of it stopped but its still loud! any suggestions on how to fix it?
HISTORY: AU series 2 S pack manual BA XR6 mock up [FLINBY] BF MKII XR8, 13.8 @ 107mph BA MKII F6 TYPHOON BA MKII XR6 TURBO BF MKII F6 TYPHOON R-spec, 13.2 @ 109 mph [LTHLF-6] PX Ranger WILDTRAK |
17-07-2006, 02:57 PM | #2 | ||
Fantastic Plastic
get yaself a car noise filter from jaycar , they are pretty cheap
the 5amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID= the 20amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID= or the 40amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID= cheers .
17-07-2006, 04:28 PM | #3 | ||
Bseries hardcore
my brother has one in his car but the noise filter then cut out his bass!
17-07-2006, 04:55 PM | #4 | ||
it could the earth for your amp, make sure its got a good earth point
17-07-2006, 07:02 PM | #5 | ||
Smile
you have a bad earth somewhere mate.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
17-07-2006, 07:39 PM | #6 | ||
my earth is under the under the back seats on the shell
17-07-2006, 07:40 PM | #7 | ||
its S-man just on my cousins account! sorry for the confusion
18-07-2006, 08:17 AM | #8 | ||
Fantastic Plastic
If the noise is that bad, try running the earth from the headunit and amp all to 1 point.
(Use nice thick ground leads). If you are running an amp too , are you using decent quality shielded coax cable ? The gold tip plated plugs help remove noise a tadd too , if your doing all the above / and have a good earth / then your probably gonna have to go for a noise filter as i mentioned earlier. By the sounds of the 1 your brother got , it is cutting into the db. range to earlly (thus cutting the base out ) , it is over filtering . I haven't checked out the jaycar ones personally , but i have seen good noise filters in the past that have had a variable knob/dial on it so you can adjust the filter until it just cuts the noise out / and doesn't start cutting into the musics db. range. / it was almost sorta worked like a squelch dial you find on a cb radio. gl , cheers .
18-07-2006, 07:35 PM | #9 | ||
A couple of years ago I had a top of the line Pioneer system fitted by JB Hi Fi, to my dedicated gas AUIII, couldn't get rid of the noise.
Turned out to be the different iginition system on the straight gas motors Normell
Every day above ground is a good day. Still Drinking & Driving, But Not At The Same Time |
22-07-2006, 02:47 PM | #10 | ||
Bseries hardcore
thanx for that guys, i spoke to an auto elec to re wire it for me so hopefully he gets rid of the noise, gl, i do have thje gold plugs in, thanks for your help anyways!
